Konia Minolta C452/552/652 NVRAM Reset Tool Firmware
  • mtavassoli
    • Jan 2020
    • 4
    #16
    Re: Konia Minolta C452/552/652 NVRAM Reset Tool Firmware
    Originally posted by Albonline
    what your describing usually happens when a bad print job is received. or when the nic is excessively pinged. try running a port monitor on your setup.
    i install printer to other PC and all of them had same problem and as i said before, first page(test page) is ok and after that it couldn't print properly even test page and printer recieve order but it print blank page with different error code, but we haven't this problem via lan, by the way i have this problem after instal new windows 10 on system and i haven't problem with this device in past.
    so i think wrong driver cause this problem and for cleaning system memory we have to update firmware
    • Albonline
      • Sep 2008
      • 1151
      #17
      the reset tool will not fix this, nor is it required to update firmware.
      • Synthohol
        Certified Konica Expert
        • 5849
        #18
        Are you making the huge mistake of letting windows install the printer by itself?
        Alway manually install a printer and driver via IP. Never ever use wsd, that's amature hour stuff.
        • darry1322
          • Oct 2010
          • 817
          #19
          So the machine was working fine.
          You changed the computer OS to Windows 10 and a different driver.
          Now you have a print issue and you think clearing the machine memory will fix it?
          Sounds like you need to fix your driver issue on the PC.
          • rafaelmanyov
            • Nov 2020
            • 3
            #20
            Hello guys. Please, help me. I have a Bizhub C452 machine that I've buyed second hand and I have replaced Image Transfer Belt Unit. I must enter service mode to reset counter, but I don't have the password (doesn't work 92729272, 1...8). I think my last option is to reset NVRAM. Could you help me please wit the reset tool and the last firmware for this machine?
            Thank you very much!
            • kendo-2004
              • Mar 2021
              • 6
              #21
              Why do you need it, do you have a specific fault/issue?
              Hi Copier Tech, if it is possible I would like to ask you for this tool also.
              In my case I have a BIZHUB C652 freezing in the booting process (timeglass). as i found it can be connected to the NVRAM problem.
              If this tool doesn't help I am resetting the FW.
              Regards!
              • copier tech
                • 8174
                #22
                Regards!
                Yes sure, contact us at the site below & we can help you out.
                We can supply the latest Printer firmware & Photocopier firmware. Click Here For - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware -
                • georgened
                  • 4
                  #23
                  Originally posted by Synthohol
                  1. Release version and download file name
                  The newly released program version and download file name is as follows.
                  [Release version]
                  <C652/C652DS/C552/C552DS/C452/C360/C280/C220/652/602/552/502/423/363/283/223 Jig firmware>
                  bizhub C652/C552
                  Jig firmware
                  GQ7-D1
                  A0P00Y0-F000-GQ7-D1.exe
                  bizhub C652DS/C552DS
                  Jig firmware
                  GQ7-D1
                  A1DM0Y0-F000-GQ7-D1.exe
                  bizhub C360/C280/220
                  Jig firmware
                  GQ7-D1
                  A0ED0Y0-F000-GQ7-D1.exe
                  bizhub 652/602/552/502
                  Jig firmware
                  GPD-F9
                  A2WU0Y0-F000-GPD-F9.exe
                  bizhub 423/363/283/223
                  Jig firmware
                  GQ7-D1
                  A1UD0Y0-F000-GQ7-D1.exe
                  [Download file name]
                  Hello there, I will be contributing on Monday, but just a question in the meantime, I have spent tens of hours trying to track down the Konia Minolta Bizhub C450 NVRAM Reset Tool & Firmware I have a Blank screen after the hourglass hangs. I am retired and love that copier, I don't make money on it it is just a Hobby. Can you please help me out with the software if you have it. thebiblecourse@gmail.com
                  Kind regards George
                  • hooman23
                    • Jul 2014
                    • 57
                    #24
                    i have problem with my c652 error number c163 and updating several times the firmware. is it possible someone send me this reset tools A0P00Y0-F000-GQ7-D1.exe
                    my email address Hooman.hedayatzadeh@gmail.com
                    thanks
                    • emujo2
                      • Mar 2017
                      • 1579
                      #25
                      Kind regards George
                      Please note...the C450 is not included in this list..The C450 requires a 128 MB compact flash card, and a special tool that only runs on Win2000 and earlier. No one is going to have this stuff any longer..Might as well ask for COMTRAN10 parts.
                      • techsxge
                        • Jan 2022
                        • 660
                        #26
                        I've got stuff like that flying around but not exactly willing to mail it to someone i dont know
