C552 turn of imaging unit warning?
+ More Options
Posts
  • mrfuser
    • 1626
    Ok we went into service mode and extra stop 0 c and told it no stop and told it not to remind consumables and yet it still pops up and fills entire user screen when idle. Any idea why?
  • Synthohol
    Certified Konica Expert
    • 5908
    Re: C552 turn of imaging unit warning?
    firmware up to date?
    did you try to disable the warning AFTER it was already triggered?
    i never had luck shutting down warnings after they were already on screen. only before.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4785
      Agree with syn, if message was already on you cant turn it off unless you replace the unit
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        I also agree that if it's already tripped no way to make it go away. Also, make sure in service mode>System 2>Consumable Life Reminder is turned off. This is the one that makes the entire screen display the message vs. just a text above to the "Ready to copy." message, unless that's what you are referring to. If that's the case, I have turned this setting off after the counter was tripped and prevented the entire screen being blocked by the message by turning off the above setting.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • Vikingrepairguy
          • Mar 2017
          • 21
          see if this helps at all
          • t85ster
            • Mar 2015
            • 39
            This doc from KonMin should help... for many older models...
            • copier tech
              • 8227
              Update the firmware, change DIP switches 50 & 51 as per bulletin reboot & the "replace IU" message will be gone it will be replaced the the L1/2/3/4 warnings but only from the "oil can" screen.
              โ€‹
