bizhub 654e Print Skew Problem
  • CopierNerd
    • Feb 2015
    • 207
    Ever since i replaced the CCDB to fix error code c-9401 the copy from ADF and Glass get skewed few mm. Print outs are tilted side ways very minor. I have checked the precise adjustments given near CCDB but no effect. any suggestion?
  • tsbservice
    Field tech
    • 8019
    Re: bizhub 654e Print Skew Problem
    Do you have manual?
    Do you have example?
    Did you carry out Main scan zoom adjust as per book after CCDB replaced?
    • CopierNerd
      • Feb 2015
      • 207
      Thanks Pal!
      I have manual.
      I have example.
      I didn't carry out main scan zoom adjust after CCDB replaced.
      The thing i noticed today is, its OK with the letter size but when i make copies on "8.5X13" it gives 2mm tilted print. Half of the print is 100% OK. rest is tilted side ways. whether i copy from platen glass or Document feeder print outs on letter paper size is perfect but on 8.5X13 inch paper it gives slightly skewed print near the end.
      Tray 1 same result
      Tray 2 same result
      Bypass tray same result.
      All this started after ccd replaced. Example print attached.
      • kingarthur
        • 1364
        Originally posted by CopierNerd
        Thanks Pal!
        I have manual.
        I have example.
        Tray 1 same result
        Tray 2 same result
        I personally wouldn't use a print out from the machine to test skew...you can't tell if it is straight....use the set up sheet that comes with the RADF, you know that is straight....
        • CopierNerd
          • Feb 2015
          • 207
          This attached image is not the original its the copy. You are saying right man but i dont have that sheet which comes with ADF. Well, it is sure that counter list table was straight when i copied but the result you can see. a bit tilted.
          I think i should try main scan zoom adjustment.
          • tsbservice
            Field tech
            • 8019
            Thanks Pal!
            I have manual.
            I have example.
            Looks like you answered yourself.
            • CopierNerd
              • Feb 2015
              • 207
              I admit i missed this step but i am not sure it will work or not. I will surely try! Thanks
              • Albonline
                • Sep 2008
                • 1151
                run a sky shot, deletion frame will be square, unless paper skew is present.
