C558 noise
    • 14972
    C558 noise
    Hey all
    I have a customer with a C558 that is producing a noise. I have been there twice without hearing it, but she recorded after I left this morning and sent it to me.
    I am unable to attach it to this post, possibly because it is too large. The noise seems to be coming from the exit area, but in the recording it i difficult ti tell. The noise is a medium pitched steady whine. The volume fluctuates slightly. She tells me it happens in the AM more often. I removed the fuser and turned it by hand and no noise there.
    I realise there isn't much to go on here, but does this sound familiar to anyone?
    Any input is appreciated
    • 23010
    Re: C558 noise
    You're right. That's not much to go on.
    If you trim down the recording to less than 1M then zip the file you should be able to attach it. Based on the intermittency ... what are the current toner levels? =^..^=
    • Woxner
      • Jul 2011
      • 853
      Re: C558 noise
      alot of times its the fuser cl roller bushing.
      • kenpio
        • Dec 2015
        • 202
        Re: C558 noise
        I have seen the transfer roller making a sqeeking noise. The front side gets dry. Throw a little oil in there and it is gone.
        • copier tech
          • 8202
          Re: C558 noise
          Exit rollers prone to squeaking, I usually just spray WD40 in that area then do a run to clear up excess. Bulletin will tell you to strip & clean or replace exit bushings etc but this is overkill.
          • allan
            RTFM!!
            • 5462
            Re: C558 noise
            79J897600Old - Crap design
            79J897612 - Hopefully fixed
            Its this holder part...
            The shaft chews thru the plastic holder until the belt starts to jump.
            Does not jam but does make a noise.
            I take the old part and drill and fix a brass bushing in there.
            Whatever
            • CopierNerd
              • Feb 2015
              • 207
              Re: C558 noise
              Yes, Sir Wayne is right! Its the fusing cleaning roller bushing. experienced this yesterday but mine was 658e.
              • CopierNerd
                • Feb 2015
                • 207
                Re: C558 noise
                I agree. if its squeaking noise then probably the cause is transfer roller. One can also check by removing the transfer roller and also by manually rotating the tr roller. Lubricating the seating works! yes! damn right!
                  • 14972
                  Re: C558 noise
                  I hope this works.
                  up close noise_output tray.mp4 - Google Drive
                  • allan
                    RTFM!!
                    • 5462
                    Re: C558 noise
                    Not the problem i am describing. Tend to agree that it could be on the fuser.
                    I have completely removed the cleaning rollers before just to get time to replace the fusers.
                    There is 3de party rebuild kits that include those roller bushings.
                    Whatever
                    • Bix
                      • Apr 2018
                      • 1421
                      Re: C558 noise
                      Make sure the transfer belt does not have problems. The other day I found out that there was some toner stuck inside the cleaning roller because they did not have to empty the waste toner box
                        • 23010
                        Re: C558 noise
                        Say it isn't so. Please don't spray WD40 on anything ... except maybe a feed roller or metal fuser inlet guide. WD40 is not a lubricant and attacks most plastics.
                        • Synaux
                          • Mar 2012
                          • 1224
                          Re: C558 noise
                          Yeap! Funny how WD40 claims it is a lubricant--blatant false advertising.
                          Rant:
                          WD stands for water displacement. I think WD40 is mostly paint thinner (and other petroleum blah blah blahs).
                          The real problem is that WD40 simply dissipates--WD40 again claims it continues to work after application which in my experience is pure snake-oil-nonsense. It is also a terrible rust prevention solvent--it is amazing how WD40's marketing team makes so many blatantly making false claims and yet so successful in their inculpability. I would be willing to bet that their sales would be cut in half (if not more) if people simply used WD40 properly (by the way that is a net income of a mere nearly 60 million USD for 2017).
                          WD40 even claims it is safe of plastics and rubber which is sort-of-true.
                          Wiping such materials down with WD40 is safe because it evaporates relatively quick; on the converse, long-term exposure will result in issues. So in my opinion, WD40 is only good for cleaning on MFPs and its residue should be cleaned off of plastics and rubbers (as a mere precaution). I guess if you have some rusted screws it would be useful otherwise, but if that is the case, you are probably having bigger issues.
                          • copier tech
                            • 8202
                            Re: C558 noise
                            Rant:
                            I’ve been using it for over 25+ years i’ve been in this industry on Canon, Ricoh, Kyocera, HP, Samsung & Ricoh never once had an issue with it damaging anything. I regually use it on squeaking exit roller bushings. Its also very good on the reg & vertical path black rollers.
                            The only issues i’ve had is being clumsy & getting some on the transfer belt or drums but even then it cleans off with no problem however it must NEVER be used in or near the fuser.
                            I agree great WD40 marketing it is also rather expensive but hey it does the job for me!
                            • Synaux
                              • Mar 2012
                              • 1224
                              Re: C558 noise
                              Well, the problem, as I see it regarding bushings, is that you are simply cleaning the bushing and shaft surfaces. If there is any lubricant present you are surely cleaning that out at the same time, therefore you should reintroduce more lubricant.
