C558 reset tool?
  • copier tech
    • 8132
    #31
    Re: C558 reset tool?
    Originally posted by Rui86
    Happy to help you can contact us at the links below.
    โ€‹
    • Barry97
      • Jun 2022
      • 23
      #32
      yes in the USA it is considered FRAUD.. and can garner JAIL TIME and/or FINES
      that's why 0 count used machines are frowned upon here in the states.
      Is it the same for Canada. Cant boot to the reset tool.
      • Barry97
        • Jun 2022
        • 23
        #33
        Originally posted by Woxner
        the file is a789be i had to get it from tech suport. pm me your email. will see if it wiil send.
        Can you email me one?
        • otphas
          • Aug 2019
          • 117
          #34
          Send me your email, i will attach you reset tool file!
          • GLAUCOB
            • May 2022
            • 8
            #35
            COULD YOU EMAIL ME, THANKS, glaucobrendo18@gmail.com
            • romario
              • Jun 2020
              • 191
              #36
              Hello, can you tell me how to use the tool for the c308? I can download it from Knova but I don't know how to use it. It would help me a lot when renting the copier.
              thanks
              • jotunn
                • 606
                #37
                I can't imagine how it could help in case of renting the machine...
                • romario
                  • Jun 2020
                  • 191
                  #38
                  I'm sorry, I don't know if I explained it well, I can download the a789be file from knova, but I don't know how to use it, it would help me to know to set it to 0, better have the accounts of the machines I rent
                  thanks
                  • Synthohol
                    Certified Konica Expert
                    • 5804
                    #39
                    then just use account track with public access. you clear the usage counter whenever you want.
                    using the reset tool just to zero the meter is immoral, irresponsible, reckless and makes your penis shrink down to a nubb.
                    dont be a nubb.
                    • jotunn
                      • 606
                      #40
                      Close your business, go back to primary school and learn how to subtract natural numbers...
                      • whitefang
                        • Jan 2018
                        • 2
                        #41
                        Hi, I can't access CE password for Konica c258. Machine is running ok but without able to access into service mode, I can foresee my future of difficulty to service the machine . I was hoping you could give me the a789be.tar file. Thank you. My Email: crab68100@yahoo.com
                        • Synthohol
                          • 5804
                          #42
                          if you ask Jotunn nicely he can help you reset it the proper way.
                          ask here.. Konica c224 e can't access service mode
                          no reason to use a hammer when a grapefruit works just as well
                          post the request code there and you will get the repair code and set the password to default again.
                          and thank you for being a contributor!!!
                          • docdot69
                            • May 2016
                            • 53
                            #43
                            There has been changes in storage data architecture since 8 series and 7 series. Reset tool clears only mfpb data, but the CE password and admin password are now stored on eMMc. Best you can do is buy the commonly named "reset device" to connect your eMMc to your pc and wipe it. Then reinstall it to your machine and perform firmware upgrade. After that perform restore data when prompted. Be careful, and do not use reset tool a789be.tar at the same time with eMMc wiped.
                            • Synthohol
                              • 5804
                              #44
                              why the hell would you do all that when you can simply get a request code and just reset the password the way the system was designed to be used?
                              this makes me laugh a bit i gotta admit, ill say again, no reason to use a hammer when a grapefruit will do.
                              • docdot69
                                • May 2016
                                • 53
                                #45
                                Because when a customer resign from the service from other company, and I asked me to help guess what.... Konica Minolta company refused to give me the code, because I didn't resell this machine..... So I had to do this by myself. For lazy people there are request codes and waiting.
