C558 reset tool?
  • Synthohol
    Certified Konica Expert
    • 5901
    #46
    Re: C558 reset tool?
    we have a member here that goes way above any beyond getting those codes for you. every single request he has answered and made sure it all worked.
    im sorry YOU went through all that, but whitefang does not have to. nor pretty much any member that asks jotunn nicely.
    thats all im trying to say
    • whitefang
      • Jan 2018
      • 2
      #47
      Thanks for the advise guys! Really appreciate. If anyone has the file, please do send to me. Last option, I will ask Jotunn for help if the reset tools won't work.
      • dansaints
        Printer Technician
        • May 2024
        • 38
        #48
        Is there a reset tool for Bizhub C266i? Please send it to me if you have.
        • Synthohol
          • 5901
          #49
          reset tool useless if you dont have a small enough USB stick to even run firmware.
          see your other thread.
          • asadk70
            • Sep 2023
            • 5
            #50
            The tool is different for some models.
            For example the C258, C308, C368 use the same tool or SATA recovery firmware.
            Hi,
            can anyone send MFP reset tool c364e many machine need to replace MFP board please ๐Ÿ™ help me
            my email asadk70@gmail..com
            • asadk70
              • Sep 2023
              • 5
              #51
              Hi,
              • copier tech
                • 8213
                #52
                Has anyone tried fitting a used CPU or MFB to the iseries ?
                โ€‹
                • elmaligno
                  Expert technician KM
                  • Oct 2009
                  • 302
                  #53
                  Yes, there is nothing to do for the Base board. For the CPUB you have to run the reset tools, choose model and type, reboot, DO NOT LOAD THE FIRMWARE, and wait for it to ask to restore data.
                  Field technician since 1994
                  • asadk70
                    • Sep 2023
                    • 5
                    #54
                    the file is a789be i had to get it from tech suport. pm me your email. will see if it wiil send.
                    Hiโ€ฆ
                    I need c364e MFP reset tool please help me โ€‹โ€‹โ€‹
                    can you send me file a789be
                    asadk70@gmail.com
                    many many thanks
                    • KM7155
                      • Aug 2008
                      • 148
                      #55
                      Guys, anyone facing error code C-C180 after enable the hdd, this c308 is without any card reader installed. at stop,9, clearly can see the card 3 there, and the UNSET is not there.
