C558 reset tool?
Re: C558 reset tool?
Hello, can you tell me how to use the tool for the c308? I can download it from Knova but I don't know how to use it. It would help me a lot when renting the copier.
thanks
I'm sorry, I don't know if I explained it well, I can download the a789be file from knova, but I don't know how to use it, it would help me to know to set it to 0, better have the accounts of the machines I rent
thanks
then just use account track with public access. you clear the usage counter whenever you want.
using the reset tool just to zero the meter is immoral, irresponsible, reckless and makes your penis shrink down to a nubb.
dont be a nubb.We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
Close your business, go back to primary school and learn how to subtract natural numbers...Comment
Hi, I can't access CE password for Konica c258. Machine is running ok but without able to access into service mode, I can foresee my future of difficulty to service the machine . I was hoping you could give me the a789be.tar file. Thank you. My Email: crab68100@yahoo.comComment
if you ask Jotunn nicely he can help you reset it the proper way.
ask here.. Konica c224 e can't access service mode
no reason to use a hammer when a grapefruit works just as well
post the request code there and you will get the repair code and set the password to default again.
and thank you for being a contributor!!!We know a thing or two because we've seen a thing or two.
why the hell would you do all that when you can simply get a request code and just reset the password the way the system was designed to be used?
this makes me laugh a bit i gotta admit, ill say again, no reason to use a hammer when a grapefruit will do.We know a thing or two because we've seen a thing or two.
Because when a customer resign from the service from other company, and I asked me to help guess what.... Konica Minolta company refused to give me the code, because I didn't resell this machine..... So I had to do this by myself. For lazy people there are request codes and waiting.Comment
