Konica Minolta C284e Duplex Paper Jamming
  • Synthohol
    Certified Konica Expert
    • 5814
    #16
    Re: Konica Minolta C284e Duplex Paper Jamming
    1.11.2 93-10
    (1) Contents
    (2) Procedure
    Step Action Control signal Location of electrical c
    1 Initial check items - -
    2 PS1 I/O check, sensor check FRB CN8-3 (ON) 4 to 5-L
    3 PS40 I/O check, sensor check PRCB CN21-10 (ON) 18-C
    4 PS41 I/O check, sensor check PRCB CN21-13 (ON) 18-C
    5 CL6 operation check PRCB CN12-11 (ON) 26-C
    6 M1 operation check PRCB CN31-2 (REM)
    PRCB CN31-5 (LOCK)
    bizhub C364e 2
    bizhub C284e 2
    bizhub C224e 2
    7 M5 operation check PRCB CN21-1 to 4 17 to 18-C
    8 PRCB ICP3 conduction check - -
    9 Replace FRB - -
    10 Replace PRCB - -
    • allan
      RTFM!!
      • 5462
      #17
      Will that paper in the image feed LEF?
      On LEF it seems wider that the paper path...
      Whatever
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        #18
        After looking more closely at the posted pic, I see your point. That has got to be B4 size (like Blackcat had guessed), not A4. And looking at how long that sheet of paper is....you are correct, no way can it be fed LEF.
        • allan
          RTFM!!
          • 5462
          #19
          Some times honesty fixes the problem. Could be that the machine times out on a sensor or even firmware related, but probably not.
          Who knows these things.
          Whatever
          • tsbservice
            Field tech
            • 8001
            #20
            Picture he posted paper is A4-R(SEF), it also jams on A4(LEF). Тhat is my understanding.
            I have to admit, I may be wrong. After second look paper on picture seems too long. I guess BC assessed/measured it correct.
              • 23003
              #21
              I just looked down the list and found an ISO paper size just a little bigger than US Folio. And yes I thought too that at ~13" or 14" it could not possibly pass LEF through a C284e. =^..^=
              • tsbservice
                Field tech
                • 8001
                #22
                May have to correct myself again.
                • allan
                  RTFM!!
                  • 5462
                  #23
                  And the OP is MIA.
                  Whatever
                  • ferro10
                    • Jun 2015
                    • 117
                    #24
                    hello I have the same problem on a c554e how did you solve?
                    • Bix
                      • Apr 2018
                      • 1421
                      #25
                      Hi, it would be appropriate to create a new thread with the characteristics of your problem.
                      • Oystercopy
                        • Oct 2009
                        • 623
                        #26
                        There is a known issue with this series machine, with the duplex switchback gate solenoid. The cure (which I have not done in a couple of years), is to add a spacer (I've used the corner of an old credit card) and put it in between the solenoid plunger arm and the frame. Gives the solenoid less ability to open (which I assume has something to do with timing?) and keeps the gate open longer. I can't put my hands on the bulletin/info at the moment, but a buddy of mine originally found the problem and reported it to KM.
                        Hope this helps.
                        OC
