C552 - removal of exit rollers assembly?
  • ECA
    • Dec 2014
    • 61
    Hi guys
    i've just installed a new fuser unit. however noticed the rollers above the fuser are dirty or worn.
    does anyone have any guidance on out to remove the exit rollers.
    ive got the field manual, but nothing in that.
    and closest i have found on interwebs is this (although different)
    YouTube
    basically i need to do a complete clean of everything lol
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: C552 - removal of exit rollers assembly?
    well here is the exploded view which can help knowing which screws to take out and where parts fit.
    hope this helps.
    also i just use alcohol and a scotch-brite for rollers.
    and the reversal unit.
    • ECA
      • Dec 2014
      • 61
      hope this helps.
      thanks, its the reversal unit that im trying to get at to clean.
      hard to figure out if this comes out in one piece or not?
      • Bix
        • Apr 2018
        • 1421
        Hello,
        the procedure is quite long. You must remove the paper exit unit and to do so there are several screws to be removed between the front, rear and the screen of the machine.
        I advise you to read the manual for more details.
        • ECA
          • Dec 2014
          • 61
          Originally posted by Bix
          Hello,
          got the field manual, but cant find the section. can you point me to it?
          • allan
            RTFM!!
            • 5462
            That is were you wing it. There is a lot of covers coming off to get it out. Plan for 2 hours.
            Would take about 20min strip and 20min to clean 30min assemble if you keep at.
            There is always another cover in the way..
            Whatever
