Konica Minolta C284e uneven image
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C284e uneven image
    Konica Minolta C284e image is not straight from Both ADF and Platen glass.
    Please find the attached and advise. Original kept as LEF on the ADF and Glass.
    Many Thanks and Regards,
  • allan
    RTFM!!
    • 5462
    Re: Konica Minolta C284e uneven image
    Don't think its your platen.
    ADF and engine. You test print could be skewed.
    Adjust you DF then run the DF setup sheet thru it.
    If still you of range adjust you original stop position.
    Whatever
    • mearmi
      • Oct 2010
      • 350
      Thanks For your reply. There is no problem with printing.
      print is fine. Attached is a Scanned image
      getting this problem when Scan/Copy. From ADF and Platen Glass is same.
        • 15069
        The front left corner of the scanner bed is likely sagging. When this happens I will remove the left scanner cover, loosen the six screws and while lifting up on the left corner, tighten the screws again.
        If that is unsuccessful just grab the front left corner of the scanner bed and lift up sharply.
        • rrrohan
          • Sep 2011
          • 1977
          its funny how common this fix is. first time i tried it i was shocked that it worked
          • copytechman
            • Nov 2008
            • 969
            Been there! Done that! Got the T-shirt!
            Regards!
            A.
              • 23010
              We used to call it the "Ricoh Bear Hug" because it was so common on Ricohs from the 90's. =^..^=
              • Gaffers01
                • May 2011
                • 336
                Agree with the above, but sometimes ive had to adjust the scanner position on the scan cable (front only)
                its a bit trial and error but eventually you can get it back to spot on.
