C364 32-01 exit jam
  • mrfuser
    • 1626
    C364 32-01 exit jam
    OK looks like the gate is not operating properly And we have increase the tension on the spring we are still getting jam so do we need to replace that whole exit assembly?
  • escalante
    • Sep 2018
    • 115
    Re: C364 32-01 exit jam
    C284e - J32-01
    Enviado desde mi SM-J701M mediante Tapatalk
    • REGSIS
      • May 2016
      • 436
      Replace: A161R72644 Soleniod assy
      Problem solved.
      • arahael
        • Mar 2013
        • 97
        remove sponges at gate and right cover. and check that solve your problem
        • SAR
          • Jul 2009
          • 206
          solenoid.jpg If your 32-01 jam is happening on the first copy of a 2 sided run, then as Regsis mentioned, this solenoid assembly will fix it. You can also just order the Holding Part which is attached to the solenoid to fix the 32-01 jamming problem. The part number is A7PU890800 for the holding part.
            • 14988
            I have just used a small metal piece and screwed it into the top of lever to "force" gate to open.
            • REGSIS
              • May 2016
              • 436
              • tsbservice
                Field tech
                • 8056
                Cool if you have new part in stock, if not 5 bucks + one more visit and unhappy customers
                  • 14988
                  This takes about five minutes, no need to stock parts I may never use. No brainer for me
                  • Oystercopy
                    • Oct 2009
                    • 624
                    I believe this can be solved by putting a spacer in between the solenoid and the frame. It has to do with the solenoid staying open longer than necessary during duplexing operation.
                    OC
                    • mrfuser
                      • 1626
                      How can it be 5 minutes? Especially when you have a bridge unit for the finisher? Stupid screw behind plastic piece under control panel makes it most time consuming. Am I missing something?
                      • Synthohol
                        Certified Konica Expert
                        • 5900
                        LOL, a bit of overkill
                        for a long time i just use 2 stickers from the panel stickers in the area shown in yellow. just stick them behind the pintle where it contacts the frame.
                        it keeps the solenoid partially engaged and never jams again.
                        • mrfuser
                          • 1626
                          • MVPunisher
                            • 209
                            This is the fix right here if you dont want to come back with parts. I have done this exact thing probably 30 times and it fixes it every time. I keep hard mylar in my bag for just this purpose.
                            • mrfuser
                              • 1626
                              So this solenoid is the one buried behind plastic piece down behind the control panel area correct?
