How do I read this.
  • Synthohol
    Certified Konica Expert
    • 5798
    #16
    Re: How do I read this.
    warnings are turned off so consumables can run almost 150% if not more which does reduce the CPC.
    the other thing is overages also offset the CPC as well.
    we also have a steady warranty exchange income from all MFGs
    we are a 5 brand dealer, and there are monthly charges as well to have a contract.
    we also have accounts in more than 5 states and tons of IT managed accounts.
    im assuming any deficit in the "click vs con$umable" cost is well offset by other means.
    the last thing is the clicks on a hundred+ of production machines and hospitals we have out there also keep me spoiled with OEM only items.
    • denvertan
      • May 2019
      • 82
      #17
      In Canon we can reset the hardisk to restore all setting to factory default.
      Does Konica have this function ? Please help to guide me on this if it exist ?
      FOUND THE INITIALISE AND COMPLETED IT.
      • kingarthur
        • 1325
        #18
        Originally posted by denvertan
        All replaced with compatible。
        But now print out alignment is out. Top part slightly to left, bottom slight to right.
        Post a sample, I know it seems a stupid question, but are the side guides actually touching the paper correctly in the cassettes, I've seen engineers spend ages trying to sort skew, when the paper was loaded badly....
        • Rao12
          #19
          You'll generally find conventional tengu masks crafted from wood, paper mache, and plastic. Today they're worn in theatre performances, featured in festival and often hung in homes as symbols of symbols luck, believed to frighten awful spirits.
          • copier tech
            • 8132
            #20
            I think you posted on the wrong forum or even wrong website!
