How do I read this.
  • denvertan
    • May 2019
    • 86
    [Misc] How do I read this.
    I am new to Konica Copier, have been working on a old C364e I bought last week and I come across this.
    Can some help me on this ?
    100% is NEED TO change ? OR
    0% is NEED to change ?
    If there is a manual on this please share with me it will be a great help to me.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4750
    Re: How do I read this.
    0 % is end of life. Looks like all the drums need to be replaced. If contract customer and quality still looks good leave it alone until you have quality issues. We turn off the message and run it until a line, light print, etc. Then will replace the drum or transfer belt at that time.
    • denvertan
      • May 2019
      • 86
      How do I turn off the message ?
      • dave w
        • Jun 2015
        • 230
        have been asked here before
        how to turn Iu life stop Off ?
        • Synthohol
          Certified Konica Expert
          • 5878
          stop 0 clear, life stop.
          • kingarthur
            • 1383
            Keep an eye on the CQ, there is potential there for a DV unit to fail, if it does, you'll need to replace all the drums that are past life, or else you'll just keep having to replace the DV unit
            • denvertan
              • May 2019
              • 86
              It already giving me C2558 error code.
              • Synthohol
                • 5878
                replace all 4 drums and a black DV unit.
                dont be cheap about it
                those units have been in there for 5 years man, just buy OEM and it will last for a long time.
                • denvertan
                  • May 2019
                  • 86
                  When replacing the drum and DV I also need to replace their chips right ?
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4750
                    You can use the less expensive Black drums instead of the color units. Just have to change the black chip. New chips are riveted in so you need to break the old color chip to remove. There are chips sold now with a cutout to fit around the rivet.
                    • Synthohol
                      • 5878
                      no, they come on the OEM units already.
                      unless you take the cheapy way out and try to rebuild. good luck with that, ive never ever been a fan of rebuilding drum or DV units.
                      my company's click charges cover the cost of OEM replacement without being greedy.
                      • tsbservice
                        Field tech
                        • 8041
                        It depends on what you planning to do with this machine. Cost of all new OEM drums and K developer unit will be close to the price of whole machine. There's troubleshooting that can be made by qualified techs to determine if/or what have to be changed. Of course best way is most expensive
                        • denvertan
                          • May 2019
                          • 86
                          All replaced with compatible。
                          But now print out alignment is out. Top part slightly to left, bottom slight to right.
                          • copier tech
                            • 8195
                            You have now learnt a valuable lesson NEVER USE COMPATIBLE!
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4750
                              Hey Synthohol We are both in NJ and not sure what the click charge is up North in state, but here in South Jersey average click is 8/10th's of a cent for B&W and 6 cents for color. I've crunched the numbers and can't find any profit in the contract if every consumable is replaced when indicated even though quality is good. Add to this toners, waste boxes, etc. I'm not even factoring in the labor cost because the main factor of losing $$$ is the consumables!
                              I even ran this past my friend who works for one of the largest Kon/Min dealers is USA and they turn off all supply messages for contract customers and leave on for Non-contract. He had a good point the whole reason Kon/Min added the feature to turn off messages several years ago was for the dealers who were complaining about not making a profit. I believe it was implemented with the C253.
                              I've had great results rebuilding kon/min drums with aftermarket drum & blade. Now that aftermarket Grid & Sawtooth charger are available they are like 100% new when rebuilt.
                              Or if for a non-contract customer I use new OEM black drum and convert chip for color. Saves customer $$$ and I make more money.
                              Can even use the OEM black dev units for colors but that's something I don't want to discuss publically.
