bizhub 558e code c 3b03
  • brent
    • Nov 2008
    • 1214
    its done it I guess 3 times.. I have a customer making like 10k copies/ prints per week
    and when they really use it heavy it will throw this code.. fuser looks fine.. meter is 245k
    I read the manual IH error. what direction would yall do start with fuser? It hasn't thrown the code
    in a year.. but ya never know. thought I would ask the experts.. thanks
    brent
    • 23010
    Re: bizhub 558e code c 3b03
    Interesting reading.
    Essentially the description in the manual is that the wiring or load are incorrect from the fuser. Since it's intermittent, I wonder if you don't have a zero-cross error. I would be worthwhile to hook up the power quality analyzer for 48 hours and see what sort of anomalies pop up. =^..^=
    • brent
      • Nov 2008
      • 1214
      I thought it was power realated as well.. trying telling the customer that. lol if this continues I will have an electrician check out their power for sure
      thank you!!
      brent
      • Woxner
        • Jul 2011
        • 854
        there are bullitens on this. do latest firmware and spec. firmware. it takes care of it most of the time.
        • allan
          RTFM!!
          • 5462
          Interesting. Would that mean that the max positive peak is higher than the max negative peak or visa versa?
          That would give more RMS power on the positive than the negative. That would be bad for transformers, SMPS and motors.
          Not sure how an AC voltage could be offset like that.
          Sure brownouts could be one cause.
          Whatever
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            ive seen it plenty on induction fusing 8 and 8e's, even second day on site of a brand new machine. I'm absolutely convinced its power related as you will reset it and goes away either forever or a very long time.
            On a side note i had a 758 with induction power source errors every morning and a new ihpu fixed that, but thats the only machine that I've changed something on for it.
            Remember back to the dark days of c250's and c352's going around resetting fuser errors was a daily job.
            • brent
              • Nov 2008
              • 1214
                • 23010
                Congratulations on finding the issue. I'm surprised there wasn't other damage with crashing servers and PCs. You should really have uninterruptable power supply on this machine.
                Zero-cross error is a frequency issue. Each time the AC sine wave crosses the zero volt level the copier can turn on the heater so as to draw the least amount of power. In the US this happens 60 times per second, or 60 hertz. So the copier has to anticipate each occurrence of the zero-cross. If the frequency fluctuates widely enough, the heater is coming on before or after the zero-cross, drawing more energy. During a shutdown like that I'd imagine the voltage and frequency would vary wildly.
                • chisnas
                  • Feb 2012
                  • 17
                  Re: bizhub 558e Service Manuals
                  does anybody have the service & parts manual for the konica minolta bizhub 558e?
                  • tsbservice
                    Field tech
                    • 8082
                    Yes.
                    • Synthohol
                      Certified Konica Expert
                      • 5922
                      Contributors seem to get what they need every time.
                      Just saying
                      • chisnas
                        • Feb 2012
                        • 17
                        thanks!
                        • tulintron
                          • Jul 2014
                          • 668
                          Good morning people. Sorry for resurrecting this topic.
                          New customer with flashing C-3B03. I would like to go prepared.
                          I will follow Blackcat's tips.
                          I'll take the measuring device like Brent.
                          I also want to take the firmware related to the error as Woxner said.
                          If you tell me which bulletin or FW. I can see if I have it.
                          Thank you guys.
                          • emujo2
                            • Mar 2017
                            • 1579
                            I would agree with the UPS, but only if it's a very short time they need to keep power on..Anything that can actually run a 558e for extended time is going to cost $3K. E
                            • tulintron
                              • Jul 2014
                              • 668
                              Thank you guys.
                              Good morning people. Giving a segment to the aforementioned problem, I took the esp surgeX device for reading and evaluation, but it didn't even turn on.
                              The equipment is turned off waiting for an electrician to solve the problem.
