help konica minolta c360 stripes on the printout
  • Mikolaj1312
    • Aug 2017
    • 14
    I am asking for help and giving the reason, the konica c360 printer only have stripes appearing on the printout in blue.The cyan drum, Magenta drum, transfer belt and transfer roller have been replaced.pictures attached.Please help
  • mo0651
    • 1054
    Re: help konica minolta c360 stripes on the printout
    That is the CYAN dev unit needing to be replaced.
    • tsbservice
      Field tech
      • 8082
      Agree with mo0651. This corkscrew pattern is definitely cyan developer being depleted.
      • Mikolaj1312
        • Aug 2017
        • 14
        replace only the powder or the entire cyan assembly
        • Synthohol
          Certified Konica Expert
          • 5922
          Always the whole unit.
          If there is any defect in the unit that caused it to deplete the developer you will be back again and finally just replace the unit.
          • Mikolaj1312
            • Aug 2017
            • 14
            Thank you for valuable information!
            but can I just change the powder or do I have to replace the whole team
            • Mikolaj1312
              • Aug 2017
              • 14
              thank you for the information I am working on
              • Mikolaj1312
                • Aug 2017
                • 14
                please help me during printing, such stripes are created,
                the developers replaced and two black and cyanwhat to do print error attachedPlease help
                Mikolaj
                  • 23010
                  Is the primary transfer belt cleaning properly? =^..^=
                  • femaster
                    • May 2011
                    • 1527
                    Mikolaj1312,
                    Same thought as blackcat, it's the transfer belt. Those are the calibration patches being smeared across the belt because the cleaning unit on the belt is not working properly.
                    • copier tech
                      • 8237
                      Mikolaj
                      [ATTACH=CONFIG]47248[/ATTACH]
                      Take out the transfer unit, remove the cleaning unit, vacuum it out clean the blade this may resolve the issue if the lines return order a new transfer unit.
                      • allan
                        RTFM!!
                        • 5462
                        Once like that you can scrap the cleaning blade. You can replace the blade with a 3de party blade but don't expect it to last long.
                        Whatever
