KM Feed rollers
  • stan780953
    • Feb 2011
    • 47
    KM Feed rollers
    Hi All,
    Is there anyone using an alternative feed/separate roller the common red one used in most KM devices?
    Thank you.
  • Toxic
    • 698
    Re: KM Feed rollers
    I cant see need for looking replacement when OEM work just fine and not expensive.
    Just to mention, i notice old machines (420,501...) paper feed rollers lasts much longer then on newer series.
    • rigthejig
      • Jan 2015
      • 14
      Re: KM Feed rollers
      WE use rollers that we fit to the existing shafts, we remove old rubber and fit these, part no A00J563600, that we buy from a supplies company, they last about 200K, and can be fitted in either direction.
      • tsbservice
        Field tech
        • 8020
        Re: KM Feed rollers
        I second that, but the world is wide people are different
        • allan
          RTFM!!
          • 5462
          Re: KM Feed rollers
          With my experience on 3de party rollers, the answer is no they are pretty crap.
          Whatever
          • REGSIS
            • May 2016
            • 435
            Re: KM Feed rollers
            OEM only. Yes old ones last twice longer but are twice expensive.
            Use the one you prefer, they are compatible!
            • Toxic
              • 698
              Re: KM Feed rollers
              Yup, i know they are compatible but new roller type is ok with life about 100k without problems for about $3-4 for piece.
              Rollers price is so meaningless in cost calculation compare to everything else much expensive (toner,drum,belt,fusing...) and i cant understand why somebody using compatible rollers anyway.
              When i said this above i refer to A3 mfps and production series but for A4 mfps is other storie.
              I dont have much expirience with new A4 mfps but recently i ask about price for ADF pick up rollers bizhub 4050,4020... and shocked when get price from KM about $120.
              This rollers have twice price of imaging unit for example,not real.
              After that even more hate that small pieces of crap mfps.
              For this series i would buy compatible rollers if somebody have infos because this "official" price is insane?
                • 23009
                Re: KM Feed rollers
                You might look at the Lexmark OEM parts. They ARE for the most part Lexmark rebadges, and the only difference is black, not gray rubber.
                • rrrohan
                  • Sep 2011
                  • 1977
                  Re: KM Feed rollers
                  yeah i dont bother carrying A108563900 rollers anymore i just pull the rubber off a A00j563600
                  • copier tech
                    • 8170
                    Re: KM Feed rollers
                    • EarthKmTech
                      Step aside, noob
                      • May 2009
                      • 2139
                      Re: KM Feed rollers
                      For those with limited space - you dont need to carry or use the old a00j red rollers anymore. Many of our techs now fit the pink, clippy rollers with grey cores (a64 part number) to everything.
                      You can pull out this grey core and use it in place of the a108 rollers too - also without issue.
                      I have a c360i already with 100k on it so that will be the first i series i'll have to change rollers on at some stage - I already have their rollers and other parts in stock but have not needed them yet. (except for a factory destroyed belt that needed replacement)
                      • copier tech
                        • 8170
                        Re: KM Feed rollers
                        • tsbservice
                          Field tech
                          • 8020
                          Re: KM Feed rollers
                          Good advice, those a64j are even low priced plus 50% more expected life.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4718
                            Re: KM Feed rollers
                            I use mostly China rollers. Like other poster I put them on oem shafts. If you get them from the right source they are same quality as oem. Wouldn't be surprised if they are coming from same factory.
                            I do use only OEM for black ribbed roller.
                            Where the real saving is using the aftermarket rollers on ADF's , no way in hell I'm paying $30 for a paper feed roller, A143563100, etc !!!!!
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              Re: KM Feed rollers
                              My bag contains everything but the kitchen sink as I absolutely detest having to walk back to the car unless necessary.
                              I even went from obese to skinny (by choice lost 35kg) and still hate walking back to the car. Obviously when belts or fusers etc are needed its still unavoidable.
