KM Feed rollers
  • allan
    RTFM!!
    • 5462
    #16
    Re: KM Feed rollers
    Originally posted by EarthKmTech
    For those with limited space - you dont need to carry or use the old a00j red rollers anymore. Many of our techs now fit the pink, clippy rollers with grey cores (a64 part number) to everything.
    You can pull out this grey core and use it in place of the a108 rollers too - also without issue.
    I have a c360i already with 100k on it so that will be the first i series i'll have to change rollers on at some stage - I already have their rollers and other parts in stock but have not needed them yet. (except for a factory destroyed belt that needed replacement)
    Please can you share the full part number for those, out of the loop with the newest stuff out there.
    Whatever
    • tsbservice
      Field tech
      • 8020
      #17
      Re: KM Feed rollers
      Here you are:
      A64J564101
      • copier tech
        • 8172
        #18
        Re: KM Feed rollers
        Here you are:
        A64J564101
        That's the 8 series roller its more expensive that the original A00J563600
        • tsbservice
          Field tech
          • 8020
          #19
          Re: KM Feed rollers
          Here you are:
          A64J564101
          No, here that is not for 8 series. That is feed roller for BH C250i.
          A00J563600 is feed/sep roller for C258.
          • copier tech
            • 8172
            #20
            Re: KM Feed rollers
            In The UK the 8 series come with the clip in rollers A64J564101
            • Bix
              • Apr 2018
              • 1421
              #21
              Re: KM Feed rollers
              Are there any advantages to putting iSeries rollers in the 8 series?
              I started with KM which provided three identical rolls for everything, then 2 + 1 and now all different
              • srvctec
                Former KM Senior Tech
                • Oct 2009
                • 827
                #22
                Re: KM Feed rollers
                Agreed
                Here in the US, the 8 series (C458) parts manual I just looked in, has the A64J564101 listed as the stock feed roller.
                Same here in the US.
                Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                • tsbservice
                  Field tech
                  • 8020
                  #23
                  Re: KM Feed rollers
                  Check C258 parts manual, you may be surprised
                  • srvctec
                    • Oct 2009
                    • 827
                    #24
                    Re: KM Feed rollers
                    That's what I figured, the smaller machines held onto the older rollers.
                    • Dev_nos
                      • Jun 2011
                      • 5
                      #25
                      Re: KM Feed rollers
                      Originally posted by copyman
                      I use mostly China rollers. Like other poster I put them on oem shafts. If you get them from the right source they are same quality as oem. Wouldn't be surprised if they are coming from same factory.
                      I do use only OEM for black ribbed roller.
                      Where the real saving is using the aftermarket rollers on ADF's , no way in hell I'm paying $30 for a paper feed roller, A143563100, etc !!!!!
                      Can you give the name of your China Supplier please?
                      Thank you!
                      • Synthohol
                        Certified Konica Expert
                        • 5847
                        #26
                        Re: KM Feed rollers
                        A00j563600 rollers are like 8 bucks if you are a legit dealer or can buy from one
                        • femaster
                          • May 2011
                          • 1514
                          #27
                          Re: KM Feed rollers
                          I know this is quite the antique thread here, but I'm in the market for a new source of after market tires. We had a source from China, through AliExpress, but after many years of purchasing from them, it would appear that our source has dried up. The tires were just under 1/2 the price from the OEM KM tires and no matter how closely they were examined, I could not tell the difference between the OEM and the tires they were selling us. Even the bags they came in were identical.
                          I was wondering if you were still getting your tires from the same source, and if you would be willing to divulge where you are getting from? I'm about to embark on a not so fun journey of requesting samples for a bunch of different sellers on AliExpress once again, but was hoping that maybe you had some information to save me a little time on that journey.
                          Thanks in advance for any leads.
                          • Synthohol
                            • 5847
                            #28
                            IF THEY ARE THIS COLOR, THEY ARE GARBAGE.
                            the OEM 8.00 rollers below will always be the best.
                            this color GOOD!!
                            • Hansoon
                              • Sep 2007
                              • 3389
                              #29
                              In the past I used those rollers from after market companies here in Europe as well direct from China from different suppliers. NONE of them last longer than 60K. Many of them not even 30k, so I started to use original OEM. Double the price, but in all cases double the lifetime of the Non-OEM.
                              Not having to go to the customer and not having the irritation on the customer's side because of jams is valuable too. Then I'd rather pay each USD 3.50/pc for those 3 pcs A00J563600. Every second replacement of the rollers, the one-ways are being exchanged too. Additionally, the shafts are scuffed up with very fine sanding paper and everybody is happy.
                              Just last Friday I had a BH-C-284e, LCC which made with those rollers 230k!
                              Hans
                              • FredJ
                                • Jun 2019
                                • 9
                                #30
                                this color GOOD!!
                                You cant go by color, it changes with temperature! Dark red at 85 degree f and closing in on clear at 5 degrees f.
