Re: C454e "TPM chip has been changed"
I have this bulletin also, but it doesn't say at what point I'm supposed to replace the MFPB, it just says to order one.
Also, there is a F/W update to GHV-M1 for here in the states that KM basically says HAS to be installed to prevent the TPM issue. The sad thing is the F/W came out over a year ago but all it said was to install to prevent loss of data. But it said to install the F/W on the next service call. Doesn't sound too serious, right? Fast forward to a few weeks ago and they FINALLY gave details on why this F/W must be installed on all 4e series machines (except the top two largest in the whole series, C/654e & C/754e). We've been getting more serious about installing the F/W since they actually gave details on what could happen.
IMO, this should have been one of those things they paid us to do because if you get the TPM message, it's a RPIA to get the machine back up and running according to KBA00048704. Of course, now when I try to find that KB article, it's not there.
Here are the details from it, that I have saved from the Solutions.
Problem
The MFP (bizhub 4e series) will suddenly lose it's meters and serial number
Note: The following messages will be shown and will not clear:
"TPM Chip has been changed"
"Only black and white printing is possible."
"Fax is currently unavailable"
"Banner Print Job in Queue"
Solution
CAUSE: Issue will occur after turning off the machine for a while specially after the weekend.
SOLUTION:
1. Have a new, unused SSDB, but do not install it yet.
2. Order a new MFP Board
3. Flash the MFPB with the Reset Tool 3 Times total with the old SSD Board.
4. Once the 3rd flash of the MFPB says complete, turn off the MFP (DO NOT REBOOT).
5. Install the new SSDB.
6. Insert firmware stick with (latest base firmware) and turn the MFP on.
7. When the firmware screen comes up check/correct Machine and Type, then flash firmware.
8. After firmware has loaded, turn on the MFP normally.
9. You may or may not get a CD390, Allow the MFP to perform it's recovery process if the CD390
occurs.
10.When the machine comes up, it should behave like a brand new machine again and will need serial
number entered.
11. In some cases, the entire install process may need to be done (security lines might occur.)
12.Install the preventive firmware GHVM1
The original technical bulletin is 11472.Leave a comment:
My experience is, replace both SSD and MFP, solved.Leave a comment:
did you select "backup engine data" BEFORE changing the SSDB? then choose restore after its 3rd reboot?Leave a comment:
Have you consulted SM???
There are steps for TPM..Leave a comment:
After replacing the SSDB for a constant rebooting problem, the machine asked to re-input the serial number - I had lost all info including the meters. I entered the serial # and a couple of other settings in the service mode - enabled the HDD, fixed the unit change settings - and rebooted. Now I get the message "TPM chip has been changed. Initialize TPM settings." Could I have missed a step or done something to mess this up? I only ask because I didn't get the message immediately, only after changing settings.
