C454e "TPM chip has been changed"
Thank you very much. I 'll keep in mind if i need something, although i pray not to be needed to me 😊... -
If you have a need and reason to use this tool, I will send it to you via private e-mailLeave a comment:
Edit: Finally after many hours of search (and much more luck), i finally managed to download the relevant xxxxxx.tar file. Thank you all once more ...Last edited by @ndy; 11-23-2024, 07:30 PM.Leave a comment:
As far as I know there are 3 ways to get it:- Konica only seems to give them out if you call support and convince them you need it.
- Become a site contributor and convince someone here that you need it.
- Contact copier tech or visit his website http://www.copierfirmware.co.uk/
Good afternoon. Can i ask a question please? What key words should i write on kiku knowledge database in order to download MFPB Reset Tool? Thanks in advance ...Leave a comment:
At long last... my Konica Minolta c454e is working normally by God's Grace.
I re-applied the firmware and the language has reset to English.
Synthohol I really appreicate your suport throughout the entire process
You are such a genius.
Attached Files👍 2Leave a comment:
Language set to USLeave a comment:
At the utility level, ENGLISH LANGUAGE is taken out of the list of languages....that's the issue.
at the Tech mode I have selected the languages as stated in the manual yet the language still remains JAPANESE.
Thank you.Leave a comment:
service mode. system 1, marketing area, select US. if no fax, fax should be set to OT same with wireless lan if any.
7. UTILITY (USER SETTINGS)
7.1 System Settings
7.1.1 Language Selection (1) Use
• To select the language on the LCD display.
• To change the language used on the control panel.
(2) Procedure
• The language as a default depend on the marketing area selected in [Marketing Area] available from [System 1] under Service Mode.
I.12.14.1 Marketing Area
7.1.2 Language Selection-Panel Keyboard Language Selection
(1) Use
• To set the language used in the keyboard displayed within the panel.
• When using the keyboard language different from the panel display language, you can select from the 9 basic languages.
(2) Default setting
• Panel Display Language Synchronize
(3) Setting item
• “Panel Display Language Synchronize”
• Panel Display Language Desynchronize
and finally in some admin system menu...
8.23.7 Temporary Change Language Setting
(1) Use
• To select whether or not to display the [Language] key, which is used to temporarily change the language for the control panel, on the top
screen in each mode.
• The temporarily enabled language is returned to the language configured in [User Settings] after any of the following operations.
• Main power switch
hope something helps, i think i can help with movie data too
Please I have already done this as in the Service Manual, yet language still remains in Japanese.
Would be glad if you could send me Movie data.
7.1 System Settings
(2) Procedure
(1) Use
(2) Default setting
(3) Setting item
(1) Use
• Main power switch
