Bizhub c554e, Firmware issue ??
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Customer said the machine would not recognize paper on glass unless she rebooted every time. When I arrived, I could put it on the glass and move it to different positions and it seemed to work fine . Detected all sizes of paper. I did it 15 times. Then made a copy, and now it sees nothing on the glass until you reboot. I tried loading firmware but it would not take. Going back with different thumb drive tomorrow. Wanted to know if anyone had seen this before.
  • Woxner
    • Jul 2011
    • 853
    Re: Bizhub c554e, Firmware issue ??
    clean the glass and mirrors cl underside of the glass even if it looks clean. do the erase adjustment. also ck df alignment for the magnet. some flash drive wont work. you can also try loading one part at a time controller last.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      Thanks for the reply. Cleaned the mirrors. Flashdrive was just used on a 558e, I think the file may be corrupt. Going back with 3 drives just in case.
      • Bix
        • Apr 2018
        • 1421
        Make sure with the sensor checks if its work properly.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          So far none of the basic stuff has worked. Tried firmware with a different stick, pulled a fresh file from KMBS, and on this one it would say I had an invalid external usb. Tried twice and tried the other stick twice, it was doing the same thing, not booting to anything. After I gave up on those, tried to reboot machine and it took almost 15 minutes to come up. She was pissed about the whole firmware thing. Didn't solve anything.
          • mincopier
            • Dec 2015
            • 289
            Invalid drive usually means wrong firmware or wrong format on the drive.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4765
              I have a similar issue. Bought a Biz C284e from wholesaler and everything is working fine, except it had very old F/W. It will update everything fine except NG comes up for MFP. Tried 6 different USB sticks (all work with other bizhubs) and at least 10 different F/W's, even trying to load F/W versions in steps. Still no good. Then machine wouldn't even boot. Only way I was able to get to boot up was leave usb service port open.Everything seems to work fine with port open.
              What concerns me and only reason I messed with the F/W was the issues with SMB 2 scanning. Since all the FW updated except MFP, including scanner does that mean the SMB 2 update is installed or is that done with MFP FW?
              Any ideas appreciated.
              • Synthohol
                Certified Konica Expert
                • 5892
                ive gotten lucky twice when that happens, backup addy book to USB and then if you do a system data clear (initialize) the firmware takes. then movie data then restore address book.
                • tsbservice
                  Field tech
                  • 8053
                  Try to disconnect HDD and then update FW.
                  • tsbservice
                    Field tech
                    • 8053
                    I guess you can always try if machine will scan with SMBv1 disabled on host PC.
                    As per MFP=NG message check KBA01400074 article.
