Frozen with the Konica Minolta logo Bizhub 423
  • escalante
    • Sep 2018
    • 115
    I have the following problem in a Bizhub 423. It stays frozen in the konica Minolta logo.Tapatalk Cloud - Downlaoad File VID-20191220-WA0004.mp4
    Enviado desde mi SM-J701M mediante Tapatalk
  • copyman
    Owner / Technician
    • Sep 2005
    • 4638
    Re: Frozen with the Konica Minolta logo Bizhub 423
    Have you tried loading firmware. Not sure if that model has it but newer models have a firmware reset tool.
    Or the NVRAM could be corrupt.
    • copier tech
      • 8131
      Did you try to boot up the machine with firmware on a USB pen?
      • Synthohol
        Certified Konica Expert
        • 5806
        any time ive experienced that is when the SSD board goes bad.
        will it boot into trouble reset/service mode if you hold the utility button down?
        or boot to a firmware stick?
        • tsbservice
          Field tech
          • 7983
          Check DIMMs(memory modules) on MFPB, also there is NVRAM Reset tool for NVRAM (Jig firmware) on this model.
          • escalante
            • Sep 2018
            • 115
            Thank all the colleagues for their help comments. Tell him to solve the problem by restarting the connector shown in the image. The flex.20191220_120055.jpg
              • 22999
              It sounds to me that you were lucky. =^..^=
              • allan
                RTFM!!
                • 5462
                Thank all the colleagues for their help comments. Tell him to solve the problem by restarting the connector shown in the image. The flex.[ATTACH]44445[/ATTACH]
                Machine can boot with that connector completely disconnected. Guess then that must have been a short.
                Whatever
                • copier tech
                  • 8131
                  Great tip thats one to remember!
