KM Bizhub C224
  • ShibaMom
    • Dec 2019
    • 7
    KM Bizhub C224
    Glad to find this forum. I am having an issue with a C224 and cannot figure out what is going on. This printer is at church and we upgraded our internet from AT&T DSL to fiber. The KM installer used a Silex wireless bridge to make it seen on the network. I have configured that and it shows as connected on the modem. If i attempt printing via network, it says "printer is offline" yet the Silex is clearly connected. If i hardwire directly to a laptop, the laptop sees it and the printer shows as being "idle." If i attempt printing anything, it goes from idle to one document printing back to idle in 2 seconds. After clicking on print, the light comes on on the printer as expected but goes back off and never prints. It never shows a print job in queue. I have tried a static IP, removing/adding printer, stopping/starting print spool, rebooting, and everything else. A tech came today and had no idea what to do. I would so appreciate help in this. I can print a document from my home printer and print from that but that is it. Thank you in advance
    Robin
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: KM Bizhub C224
    initialize the network settings and try again.
      Re: KM Bizhub C224
      +1 to this suggestion.
        • 23009
        Re: KM Bizhub C224
        Do you have any sort of authentication or account track set up on the machine? The most obvious possibility is that the IP range has changed with the new router, and your printer is still on the old IP range. =^..^=
        • ShibaMom
          • Dec 2019
          • 7
          Re: KM Bizhub C224
          Thank you for your reply. I will try this first thing Thursday morning. I had checked the IP address range to make sure nothing had changed there but hadn't considered this
          Robin
          • emujo2
            • Mar 2017
            • 1579
            Re: KM Bizhub C224
            The C224 is pretty old, I have a hunch you also updated your workstations/laptops..If so you may need a driver update The simple changing of a router (as long as the schema remains the same) should not affect printing..If the driver is showing OFFLINE, then this is a normal symptom that results when the SNMP protocol no longer talks to the print driver. I would start by deleting any old c224 drivers and adding the latest c224/c224e drivers. Under printer properties/config tab you should be able to querry the printer for it's accessories. If you get a failure message, this is the problem (again assuning IP schema hasn't changed). You will need to determin why the drriver can no longer talk to the printer. You may havbe some new anti virus software on the new router..ensure snmp traffic is allowed, along with port 91XX. E
            • ShibaMom
              • Dec 2019
              • 7
              Re: KM Bizhub C224
              No authentication or track settings. I checked the IP range immediately to make sure that was okay. I have been trying to figure this out since Friday but will initialize the network settings and see if that solves the issue. Thank you for your reply
              • Synthohol
                • 5849
                Re: KM Bizhub C224
                meant to ask, can you bring up the copiers web page from a local PC?
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4723
                  Re: KM Bizhub C224
                  Unless I missed it can you ping the IP address? If initilizing the network settings don't work I would iniltilize all settings in the admin mode. This should clear any setting that would lock network. Backup all the settings first to a jump drive
                  • ShibaMom
                    • Dec 2019
                    • 7
                    Re: KM Bizhub C224
                    I can via USB right now
                    • Synthohol
                      • 5849
                      Re: KM Bizhub C224
                      can you do it through the network is what im asking.
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4723
                        Re: KM Bizhub C224
                        Exactly what I was thinking. Why would you use a USB cable when you are trying to troubleshoot a network connection!
                        By the way to add to Synthohol post no crossover cable is needed with konica minolta equipment for many years now.
                        • Synthohol
                          • 5849
                          Re: KM Bizhub C224
                          plus how do you get to PSWC via USB?
                            Re: KM Bizhub C224
                            you shouldn't be able to see the WIM/Net Page from a usb.
                            that would be restricted to Cat5 connection to a newtork
                            if it is.. and you have a new router .. the setting on the new router don't juve
                            • ShibaMom
                              • Dec 2019
                              • 7
                              Re: KM Bizhub C224
                              Actually i mislead you. No i cannot access anything about the printer via web configuration. If i use a USB cable, I can access the printer settings through a laptop. The modem sees the wireless bridge but bringing up the printer is shown as offline. I was thinking about printer settings rather than the web configuration.
