c224 error c-2557
  • refillman
    • Nov 2019
    • 27
    c224 error c-2557
    hello
    i have this error c2557 which i cant get round
    ive replaced the drum and developer unit at the same time about 1 month ago every thing worked great then yesterday we had the error message, iv replaced the drum and checked the brushing, done the graduation adjustment toner is droping,
    some times you can print 10 sheets sometimes only 5 the developer was brand new when i replaced it
    please help
    Darren
    Re: c224 error c-2557
    Originally posted by refillman
    hello
    please help
    Darren
    you did intit the dev unit?
    OEM Original toner?
    • refillman
      • Nov 2019
      • 27
      yes oem toner
      intit the dev unit.... nope how do I do that, I did do a add toner cycle.
      • tsbservice
        Field tech
        • 7917
        Here, read spock's answer, different model but same faults:
        Also I believe front bushings are modified, there's bulletin about that somewhere.
        • tsbservice
          Field tech
          • 7917
          yes oem toner
          Newer Konicas are easy on that, you only need to run Gradation Adjust after replacement of dev unit.
          • refillman
            • Nov 2019
            • 27
            hi yeah i did that when i installed the dev & drum unit every thing went great until i did a big run, then just before the end it started with this error.
            ive taken the front panel off and the screw on the black tones is spinning ok
            • tsbservice
              Field tech
              • 7917
              Next one to check would be A161R71122 Sub Hopper Assembly.
                • 8104
                I've had 2 calls for this issue in the last week both times I replaced this sub hopper.
                Check the toner bottle is rotating have seen the motor that drives it fail.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4535
                  Take out black Dev unit and see if developer powder is missing (turn mag roller and see if even toner on roller). It may have dumped.
                  Keep in mind as mentioned on this forum many times, if "any" consumable is over life or bad they can affect "any" other color! Are any other consumables at 0% ? This is a chance you take when you turn off consumable reminders. Still way ahead of the game if this happens once during the life of machine.
                    • 22936
