Bizhub c224E not putting anything to paper
  • Ilsu
    • Mar 2020
    • 19
    #46
    Re: Bizhub c224E not putting anything to paper
    Originally posted by allan
    How far are you from the nearest city center?
    From nearest city where is copier service: 48km, about 30 miles.
    • allan
      RTFM!!
      • 5462
      #47
      That is around the corner that is about as far as my closest customer.
      Whatever
      • copier tech
        • 8172
        #48
        The black drum is the only consumable over life, this ran out in 2018 so i'd assume the machine has been in use for the last 18 months etc.
        From the copy screen at the top do you have a explanation mark? if so press it, if its not there the life stop setting are disabled & you can print/copy.
        You can see the print jobs in the queue & the blue activity light comes on, sound like you have user authentication or account track turned on?
        Have a look in administrator settings>User Authentication/Account Track turn this OFF.
        • allan
          RTFM!!
          • 5462
          #49
          I want to thank user Takhnamishvili from bottom of my heart! You solved the problem! Life stop setting made the trick and now machine also warns me that black drum unit needs to be replaced. Now I have to buy it and figure out how I can set the machine to understand that I print A4 and A3-sized documents and not something like 8"*11" documents
          Thank you all who helped me out with this. As told, I learned a lot already and will definitely follow and support this forum to learn more.
          He got it running a while ago.
          Whatever
          • Synaux
            • Mar 2012
            • 1224
            #50
            Originally posted by Synthohol
            not to stir the mud but i cannot find any post or announcement or rule that says this forum is for techs only nor is there a competency requirement posted.
            i thought we were all inclusive here but still poke fun at ID10ts and rip-off artists.
            when i needed to fix my dishwasher i found a forum that seemed to have mostly professionals but i was welcome wholeheartedly.
            i try to return the favor here. (unless you are asking how to reset a meter and i will rip you apart )
            Fuck it. Stir the mud. I was simply trying to explain some of the contention.
            I started here knowing nearly nothing. An old timer turned me on to this forum and strongly encouraged I use his login (due to tech-prejudgement--and status), but I took it upon myself to learn as much as I could as an indy and create my own account. I feel I have helped at least a few people in my trek too. So if someone else wants to join the party, I welcome the addition. Hell, I will even buy some of the old ornerys' a beer if I need to...I think I've said enough...
            • Synaux
              • Mar 2012
              • 1224
              #51
              I suppose none of you would come to Finland to fix this machine anyway.
              Ilkka
              Sounds like a fun trip! :P
              • Ilsu
                • Mar 2020
                • 19
                #52
                I can guarantee that it would be fun!
