C360 Document Feeder Folding Corner
  • pick
    • Oct 2015
    • 26
    The document feeder on my c360 folds the corner of the page only when running 2 sided copies. Has anybody seen this before, and what was your solution? Thanks in advance.
  • patrickjlc
    • Feb 2015
    • 225
    Re: C360 Document Feeder Folding Corner
    Check the paper path for something obstructing it, maybe a staple or piece of paper is there.
    Sent from my SM-G930V using Tapatalk
    • copier tech
      • 8174
      Most likely obstruction in the path, torn piece of paper, staple etc.
      Also check the mylar guides they get deformed.
      • Synthohol
        Certified Konica Expert
        • 5849
        i usually take a manila folder and push it through the paper path to try and have some tactile feedback to see where the obstruction is. most of the time it knocks the staple/paperclip right out and in the case of a flipped mylar it flips it back and if there is a notch/burr on a mylar you may be able to feel it through the folder or at least hear the scritch/click.
        good luck, i was so happy when KM moved to one pass adf.
        • tsbservice
          Field tech
          • 8020
          He he my little A4 Brother printers use one pass DFs, for most KonMin we sold our customers pick cheep option, I have yet to see optional dual-scan DF on our 4, 8 and i series 25-35 cpm machines.
          Agree on your trick, works best to feel or push the scrap customers put through DF.
          • allan
            RTFM!!
            • 5462
            I even spay some WD40 on it and spin the rollers against it...
            Know its the lazy way to clean a roller you cant quite get to.
            Check for torn bent or worn mylars.
            Been removing lost of "extra" guides from KM doc feeders of the years.
            Whatever
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Lift up all flaps could be damaged mylar guide good luck keep us posted
              Regards Mark
