C224e duplex jams
  • copyman
    Owner / Technician
    • Sep 2005
    • 4762
    C224e duplex jams
    I've read some bulletins and old posts about this same issue but still didn't find a fix.
    When duplexing paper will exit at bottom and jam, instead of normally coming out at top and pulled back in for 2nd side. If you put slight pressure on top of side door it works fine. Checked all the normal stuff, broken door hooks & plastic pieces the hooks latch to, turnover gate sticking, etc. Also tried adjusting the door slightly but didn't want to mess with it too much unless it's a definite fix.
    32-01 is jam code which there is a bulletin about putting on a pad to stop gate from sticking but not sure it's the fix in my case.
    I've seen a few times on other machines where the bottom hook latch was broke and tray 2 wouldn't feed unless you put pressure on bottom of door, but tray 1 would feed fine fine. But never saw this one. Machine was moved recently and only has 22k total clicks. My thought is the movers strapped it too tight and door is out of alignment. Door looks like it is lining up perfect with top & bottom.
    Anyone see this before or any ideas? My feeling is it has to be something simple but afraid to think that because every time I do it always turns out to be something big! Ha-ha
    Thanks in advance
  • copier tech
    • 8200
    Re: C224e duplex jams
    When duplexing paper will exit at bottom and jam, instead of normally coming out at top and pulled back in for 2nd side. If you put slight pressure on top of side door it works fine. Checked all the normal stuff, broken door hooks & plastic pieces the hooks latch to, turnover gate sticking, etc. Also tried adjusting the door a slightly but didn't want to mess with it too much unless it's a definite fix.
    Thanks in advance
    Does it jam every time on all paper sizes & from all trays & bypass ?
    I guess you removed the sticky pads?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4762
      Thanks for the reply. Sorry should of included, it jams all sizes and all trays / bypass. Also should of included I've been there 2 times already and thought I had it working last time for sure after running 50 duplex without it jamming. When I go back it will jam consistently until I put pressure on "top" of side door. You would think for sure the plastic hook or latch was broken. Really weird.
      Since the machine only has 22k clicks and pads were not sticky I didn't remove them. The bulletin says to add a piece of print head cleaning pad on top of sticky pad. Was going to do next visit even though pads didn't feel sticky.
      Thanks again
      • ivovb
        • 695
        Have seen several times such a problem. All the times decision is as follows.
        1. Remove Gate switch unit using chapter 5.7.2 in SM
        2. Look at the last photo in procedure - especially gate switch solenoid [4].
        3. Place 3 layers of isolandband on a metal chasis against solenoid's anchor.
        4. Confirm it's working. If not set one more layer.
        Most of the cases 3/4/5 layers are enough.
        Yes it is anoying to remove and reinstall unit for each layer. Yes You can't be sure if it works even making 50-100 double sided prints - unfortunatelly customer calls several days later and You have to back for next layer...
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • tsbservice
          Field tech
          • 8052
          BR
          That would be the fix.
          Btw, no need to do several attempts on this gate switch solenoid, 2mm are enough.
          bizhub c364e jam 32-01
          Originally posted by FixStuff
          This has fixed 3201/3205 for me a number of times.
          Article ID: KBA01500433
          ErrorJam code 32-01
          Root CauseJam code 32-01 occurs only on the first duplexed copy or print.
          Workaround/FixCAUSE: Improper movement of the paper exit/reverse switch gate.
          SOLUTION: Install a2mm thick mylar on the frame directly in front of the plunger for the Gate switch solenoid (SD3) as outlined in the illustration below.
          [ATTACH=CONFIG]32081[/ATTACH]
          • copyman
            Owner / Technician
            • Sep 2005
            • 4762
            Thanks! Exactly what I was looking for.
            • Synthohol
              Certified Konica Expert
              • 5891
              i use 2 or 3 of the panel stickers that come with the machine.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4762
                You mean the user box, etc. strip of stickers that are never used? Only ones used are the fax/scan & copy.
                • Synthohol
                  • 5891
                  yes, exactly!!
                  sometimes i get stubborn and dont even take the unit out and ill pop the stickers on with forceps and a spring hook tool!
                  • copier tech
                    • 8200
                    yes, exactly!!
                    What does putting a sticker in this location do exactly!?
                    • Synthohol
                      • 5891
                      it makes the solenoid pintle slightly engaged and the duplex gate slightly down so the solenoid engages better and faster.
                      • copier tech
                        • 8200
                        Ah ok, & this really makes a difference?
                        • Synthohol
                          • 5891
                          IMHO i think the solenoid loses some electromagnetism and fails to suck the pintle in or the axles of the duplex gate become worn and the resting position of the gate is too high so when a duplex is started the gate does not pull down fast enough to allow the page to be sent for turnover and either comes out the bottom instead or the paper get caught on the comb.
                          • copier tech
                            • 8200
                            • Synthohol
                              • 5891
                              the paper has a bit to do with it as well.
                              24#+ paper seems to do much better, after leaving the fuser, thicker paper has less curl to get stuck on the comb of the gates.
