Konica Minolta C360i
  • Albonline
    • Sep 2008
    • 1153
    #16
    Re: Konica Minolta C360i
    just an fyi trading boards around in this series is fatal, to to the entire set.
    • tsbservice
      Field tech
      • 8032
      #17
      You can try to format Storage board from Admin menu if no access to service mode:
      [Utility]
      • [Storage Management]
        • [Format]
      • karel
        • Mar 2018
        • 44
        #18
        tsbservice I can't do this
        Dropbox - IMG_20200420_085400 (1).jpg - Simplify your life
        I can do nothing more
        • Synthohol
          Certified Konica Expert
          • 5870
          #19
          try a warm boot (T/R) and try and access service mode once (OK) is displayed.
          • Albonline
            • Sep 2008
            • 1153
            #20
            You need to clear that base board ,with a reset tool, the 789 file works on it.then try loading a fresh copy of firmware.
            • Bix
              • Apr 2018
              • 1421
              #21
              I'm sure it's the STRB. A very common problem in these printers. Replace it and rewrite the firmware, it takes a few minutes. It has already happened to me in two C300i.
              • tsbservice
                Field tech
                • 8032
                #22
                Hey Bix, long time no see. Mate I'm so glad you still hanging around
                • Bix
                  • Apr 2018
                  • 1421
                  #23
                  Hey tsbservice, yes you are right! it's nice to reread you, I had a fever, cough and I no longer had the sensation of taste. But now, I believe I am healed.
                  • ivovb
                    • 695
                    #24
                    Sometimes it is worth following a different path than machine manufacturers advise
                    KM is often wrong, some models are one big mistake
                    Yes You are right and it is not only KM, but Toshiba, Brother, HP etc. I have several times of a wrong procedures concerning replacement electronic parts or solving a problem. Quite often expirience is better advisor.
                    BR
                    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
                    • karel
                      • Mar 2018
                      • 44
                      #25
                      Can you run diagnostics? If yes what it gives?
                      -Cannot perform diagnostics.
                      -warm boot does not help
                      -I did today(a789be.tar), unfortunately it didn't help either
                      -I'm planning to buy STRGB
                      Greetings to all
                      • Albonline
                        • Sep 2008
                        • 1153
                        #26
                        Greetings to all
                        get the nvme m.2 ssd enclosure. 30 usd$ on amazon. reformat the storage board , its just a standard m2 drive.
                        • karel
                          • Mar 2018
                          • 44
                          #27
                          of course, I've already ordered the M2 adapter. If the repair fails I will buy a new STRGB
                          • tsbservice
                            Field tech
                            • 8032
                            #28
                            As Controller Firmware resides on STRGB and most of the features on Controller run on device's hardware namely MFPB, corrupted STRGB may prevent device from operating normal.
                            I hope format would cure it. Let us know.
                            • Jumping Jack Flash
                              • Jul 2009
                              • 66
                              #29
                              My advice, start with the basic things and
                              change the pendriv from which you upload FW to older 1-2GB.
                              Do not start the device if you have the message N.G. It always helped
                              • karel
                                • Mar 2018
                                • 44
                                #30
                                I have tested flash drives with smaller capacity, unfortunately still N.G
