Konica Minolta C360i
  • karel
    • Mar 2018
    • 44
    [Dead] Konica Minolta C360i
    Hi,
    I have Konica Minolta C360i. I try to upload the firmware (AA2J0Y0-F000-G00-7B-990) and I get MFP N.G. Do you have any ideas how to fix it
  • copier tech
    • 8131
    Re: Konica Minolta C360i
    Originally posted by karel
    Hi,
    Does the machine come to ready or does it have a fault?
    Try the latest version GC1-7B
    • karel
      • Mar 2018
      • 44
      The machine hangs on the Konica Minolta inscription. I tried the latest software but it didn't help either. I cannot enter the service mode
      • tsbservice
        Field tech
        • 7986
        Disconnect any installed options and select all but MFPB. If rest is updated successfully select only MFPB and try again update.
        • karel
          • Mar 2018
          • 44
          I've done this before and it didn't work
          • tsbservice
            Field tech
            • 7986
            MFPB or Storage board may be bad.
            • Synthohol
              Certified Konica Expert
              • 5807
              do a data clear after backing up the address book (if any)
              or
              Solution
              CAUSE: Corrupt MFP board or Storage board
              SOLUTION: Perform the steps below.
              1. Disconnect all peripherals (Finisher, Document Feeder, Fax option, etc.).
              2. Load MFP Firmware only:
              a. Copy folder FW0020 on the root of a recommended USB drive (refer to KBA00044472).
              b. Ensure the machine is powered OFF and insert the USB drive in the front USB port.
              c. Hold down the Stop button behind the little cover on the back of the Touch Panel while powering ON the machine.
              b. Select MFP Controller ONLY and make sure all other firmware files are unselected.
              d. Press the Start button to start loading the firmware.
              e. Power OFF the machine when completed.
              3. Reconnect all peripherals (Finisher, Document Feeder, Fax option, etc.)
              4. Load all Firmware except MFP Controller:
              a. Hold down the Stop button behind the little cover on the back of the Touch Panel while powering ON the machine.
              b. Select all other firmware files and make sure MFP Controller is not selected
              c. Press the Start button to start loading the firmware.
              d. Power OFF the machine when completed.
              5. Remove USB drive.
              6. Power ON machine and test functionality.
              • karel
                • Mar 2018
                • 44
                I did as in the instructions above
                When uploading, the counter reaches 70% and then N.G
                • tsbservice
                  Field tech
                  • 7986
                  Can you run diagnostics? If yes what it gives?
                  • karel
                    • Mar 2018
                    • 44
                    The machine will not allow entering the service mode
                    • tsbservice
                      Field tech
                      • 7986
                      It can be done without need to enter CE mode, just turn on machine main switch while pressing the power key. After short beep release power key.
                      • karel
                        • Mar 2018
                        • 44
                        I will run diagnostics tomorrow.
                        Can formatting STRGB in another C360i help?
                        • tsbservice
                          Field tech
                          • 7986
                          I dunno. As usual they(KM) say boards cannot be swapped(Storage,CPU,Base) and usual blah-blah...
                          • karel
                            • Mar 2018
                            • 44
                            Sometimes it is worth following a different path than machine manufacturers advise
                            KM is often wrong, some models are one big mistake
                            • Albonline
                              • Sep 2008
                              • 1144
                              Short answer is no , but it can be formatted in an external drive converter , and then follow machine recovery procedure.
