Bizhub C554e
  • afterhours
    • Mar 2017
    • 152
    Bizhub C554e
    Does anyone know if there are special rollers that can be ordered to feed NCR with out it leaving a tire mark?
    Please help
    Im a Loser Baby!!!
  • Woxner
    • Jul 2011
    • 845
    Re: Bizhub C554e
    none that i know
    • Synthohol
      Certified Konica Expert
      • 5814
      Re: Bizhub C554e
      NCR paper isn't supported anyway.
      • Bricorley
        • Jul 2017
        • 41
        Re: Bizhub C554e
        try having them print on thick 1. Should do the trick
          • 23006
          Re: Bizhub C554e
          AFAIK vacuum feed is the only way to pick up NCR without marking it ... not available with the C554e.
          • Bricorley
            • Jul 2017
            • 41
            Re: Bizhub C554e
            Maybe Im getting lucky... I have 2 print shop customers who both use a c552 and c654e with NCR. I suppose it depends on the thickness of the sheets
            • copier tech
              • 8138
              Re: Bizhub C554e
              Please help
              Have you tried using the bypass ?
              • 3ktlc
                • Feb 2018
                • 180
                Re: Bizhub C554e
                We use the bypass on ours and set it to thick 1.
