C224e replacing dev unit and roller
  • John-r
    • Mar 2020
    • 10
    I have a konica minolta c224e, I have to change dev unit and drum. do I have to reset someting after switching? or does the printer do that automatically?
  • GIUBOSS
    • 1431
    Re: C224e replacing dev unit and roller
    hi, are you a technician? Do you have the service manual? for the developer Execute [Service mode] -> [Image process adjustment] -> [Gradation adjustment]. Replace the MFP board (battery included)
    • Synthohol
      Certified Konica Expert
      • 5822
      nothing to reset, just run 3 of each gradation adjustments
      • John-r
        • Mar 2020
        • 10
        No and no😅
          No and no😅
          if you are going to service your unit.. I would HIGHLY suggest you get a manual.
          and then STUDY it from front to back.
          • tsbservice
            Field tech
            • 8007
            Why to change DV unit?
            • copyman
              Owner / Technician
              • Sep 2005
              • 4679
              I'm guessing he read on this forum that if a dev unit crashes because of over life drums to replace both units together.
              If OEM parts are used just swap out dev & drum units turn machine on and good to go. Life counters & voltages will all reaset automatically. Like other poster said you should do gradation adj but not absolutely necessary.
