C554e during firmware update MF controller shows N.G
  • copier tech
    • 8174
  • Albonline
    • Sep 2008
    • 1151
    Re: C554e during firmware update MF controller shows N.G
    disconnect hdd try again . if that fails reset mfp . check machine type and reflash.
    • mascan42
      • Oct 2008
      • 485
      If all the other firmware except MFP downloads successfully, try doing just the MFP on its own. If it still doesn't work, try disconnecting options.
      • Synthohol
        Certified Konica Expert
        • 5849
        "MFP=NG" message
        Problem Solution
        Related Products:bizhub C554e,bizhub 224e,bizhub 284e,bizhub 364e,bizhub 454e,bizhub 554e,bizhub 654e,bizhub 754e,bizhub C224e,bizhub C284e,bizhub C364e,bizhub C454e,bizhub C654e,bizhub C754e
        Related Options:
        Problem
        "MFP=NG" message may be indicated when attempting to install firmware.
        Solution
        CAUSE: Possible corruption of the SSD board (SSDB) or Hard Disk Drive (HDD) unit.
        SOLUTION: Before performing the steps below attempt to load firmware with the HDD physically disconnected from the MFPB. If the "MFP=NG" message returns then connect the HDD and proceed.
        Format the HDD/SSD Procedure:
        If able to access the Service Mode to format the HDD or SSD, perform the following steps.
        WARNING
        : Carefully follow the steps below, as doing so will avoid any unnecessary replacement components, such as the MFPB/PRCB/HDD (when only the SSD is actually required).
        1. Press Menu.
        2. Select Counter.
        3. Select Display Keypad.
        4. Access Service Mode "Stop 00" "Stop 01".
        5. Enter 9272 4 times (Factory default).
        6. Select System 2.
        7. Select HDD and set to "Uninstall".
        8. Select State Confirmation.
        9. Select Memory/HDD Adj.
        10. Press down-arrow 2/2.
        11. Select SSD Format.
        12. Select Logical Format.
        13. Power MFP OFF/ON.
        14. Repeat steps 1 through 5 to access Service Mode.
        15. Select System 1.
        16. Select Initialization.
        17. Clear All Data.
        18. Select System 2.
        19. Select HDD and set to "Install".
        20. Power MFP OFF/ON. \
        21. Repeat steps 1 through 5 to access Service Mode.
        22. Select State Confirmation.
        23. Select Memory/HDD Adj.
        24. Use the down-arrow to access page 2.
        25. Select HDD Format.
        26. Select Logical Format.
        27. Power MFP OFF/ON.
        • If the problem is not resolved after performing the above procedure, call the CSC for further support.
        • Please install the following "4e" Series firmware if the SSD has been approved for replacement and replaced. (Note: If firmware version is later than C8 then flash current firmware or update firmware to current base)
        • copier tech
          • 8174
          Thanks for the info.
          I'm going back with a new SSD will try the suggestions FW update with the HDD disconnected.
          It wont let me access CE mode so I have limited options.
          • tsbservice
            Field tech
            • 8020
            Have you tried access CE mode through reset thingy?
            Was about to post what Synthohol posted but feeling like Albonline knows more than KM tech support.
            • copier tech
              • 8174
              "reset thingy?" you might need to be more specific?
              • tsbservice
                Field tech
                • 8020
                Not in public.
                • Synthohol
                  • 5849
                  hey, i also thought about making sure the machine type is entered correctly.
                  if you print the network config page does it show the correct model?
                  • Mr Magic
                    • Jan 2020
                    • 29
                    Try down-grading the FW!
                    • copier tech
                      • 8174
                      I'm onsite now.
                      • first again tried latest firmware GDN-M1 same issue control N.G
                      • Tried downgrading with GDF-M1 same N.G message
                      • Fitted new SSD & powered back on with GDN-M1 this time all firmware shows OK & print button is blue.
                      • Shut down the machine removed the USB pen.
                      • Powered back on machine takes ages to boot up but finally came ready!
                      • I believe this machine had the old faulty type SSD & factory firmware so when I updated to the latest 7 year firmware this caused the issue.
                      • femaster
                        • May 2011
                        • 1514
                        I'm onsite now.
                        That SSD you pulled out might still be OK, even if it was one of the earlier problem ones.
                        Since the firmware hadn't been update previously, it's possible that the SSD contained older firmware and couldn't be updated with the main firmware. Toss the SSD into a machine back at the office and run the "SSD Board Tool" (A5C10Y0-F000-G00-A9-04--SSD-FW-Ver6.03m.exe) on it. It will update the firmware if it needs it, or will tell you if the firmware is already updated. If it does update the firmware, then you will also need to run a regular firmware update afterwards as newer main firmware will update the SSD further.
                        The main firmware won't update the SSD unless the SSD has version 6.03m or newer on it. If it's older you MUST run the SSD Tool first in order to update the SSD to V6.03m.
                        • tsbservice
                          Field tech
                          • 8020
                          Exactly my thoughts.
                          • copier tech
                            • 8174
                            Thats a good shout it had SSD version 6.01a so if I had updated that version first then my main fw most likely would have worked! I will keep this the old SSD for the next rebooting loop issue!
                            As it happens customer rang back saying she cant scan to email & that the scan option is missing? When I first turned the machine on it changed from manual IP to DHCP & lost the original IP so I had to set that back.
                            Would a new SSD also have turned off the scan to email option!?
                            • tsbservice
                              Field tech
                              • 8020
                              Check in System 2 that HDD is installed.
