BHC654 no one touch boxes
  • digicor
    • Jul 2008
    • 1159
    Ive added useres to the one touch screen, checked favorites, yet there stil not there
    I chek in admin mode and there there but they have PE001,PE002 etc in front of the number
    is there something keeping these from being in the user box????
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: BHC654 no one touch boxes
    please explain more, user box has nothing to do with one touches
    please post pics so i can see what you are trying to setup.
    are you scanning to a folder, email or a user box?
    thanks.
    • digicor
      • Jul 2008
      • 1159
      sorry,
      scan to email, usually has the one touch boxes in the screen after i input info,
      the info is there when you go to edit one touch boxes in admin mode, but are not there in user mode when the client goes to scan to email
      • Woxner
        • Jul 2011
        • 850
        are you using authentication? i had a c368 do this after this was on and bizhub secure was done. had to login to account to email. think is was so public user could not use email
        • digicor
          • Jul 2008
          • 1159
          no authentication being used,
          no restrictions on, that i can find
          • femaster
            • May 2011
            • 1514
            Have you checked in the letter section of the onetouch address book screen to verify that they show up there? I'm not sure if you realize this, but if you want the buttons to show up in the FAVORITES tab in the address book, you have to make sure that you select the check box for "favorites" when you program in the onetouch.
            UPDATE: I made a quick look in the manual, but couldn't find where it talked about the favorites tab. I believe that when programming a destination at the copier, you need to select the INDEX button, and in there is where I believe you will find the selection to add the address to the favorites tab...
            • digicor
              • Jul 2008
              • 1159
              nothing in the letter index section either
              • digicor
                • Jul 2008
                • 1159
                okay ill try that with the "index" button
                • Synthohol
                  • 5847
                  its true, ive typed in dozens of names and they all wound up in "etc"
                  never again.
                  • srvctec
                    Former KM Senior Tech
                    • Oct 2009
                    • 827
                    The favorites option on the copier screen is the same as the "Main" checkbox on the web interface on these models.
                    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                    • emujo2
                      • Mar 2017
                      • 1579
                      If scan to email is turned off in Admin mode then your email one touches will not show up on the home screen. E
                      • digicor
                        • Jul 2008
                        • 1159
                        this is checked, i manage to get a Program going with thier names and emails in a button...
                        i have never had this unless the send to email is off... and if it was off then it wouldn't email... correct?
                        • digicor
                          • Jul 2008
                          • 1159
                          where in admin mode is this just in case...
                          • emujo2
                            • Mar 2017
                            • 1579
                            Through LCD ADMIN/NETWORK/SMTP-TX 1st screen gives you the choice to enable scan to email functions, through PSWC..Login as Admin, network tab, SMTP-TX. E
                            • digicor
                              • Jul 2008
                              • 1159
                              yes that is on...
