Saw this post here:
Our copier has moisture accumulating on the fuser exit guide, and jamming at the paper exit assembly. We are buying the fuser, does the new fuser come with the Guide Film Additions per Bulletin Number 7587?
Lastly, the paper exit door's guide broke and now the spring there is loose. I'm replacing the guide and purchasing the slide tape per that bulletin too.
My question is this, I scoured the manual, and I can not, for the life of me find simple and clear instructions on how to remove it, and replace the guide.
Is anyone here familiar with the machine? Maybe I'm blind, but honestly, I looked, and did not find anything on the paper exit, and how to remove and replace that guide.
Any instructions and advice would be GREAT. Also, how many hours do you suspect it will take to replace?
Parts: All parts in Bulletin 7587
A0ED741400 Guide Film Item Addition
A0ED897200 Slide Tape Item Addition
AND:
A0ED 8904 01 Guide
4038 5896 02 TORSION SPRING
4163 5293 01 SCREW
A0ED R720 00 Fuser Unit(120V)
Thank you!
AND:
A0ED 8904 01 Guide
4163 5293 01 SCREW
Thank you!
