BH-363 dead
  • Hansoon
    • Sep 2007
    • 3391
    BH-363 dead
    Got from a wholesaler a very clean and nice BH-363. Counter is showing only 49K. Everything is super clean but the machine does not start up. Display remains dark but machine is firing up otherwise and even the heater comes on. Based on the screws missing from the backpanel and other traces I could imagine that one messed up with the NVRAM etc.
    Anyone having for me please the NVRAM reset tool for the BH-363, 423 series?
    Thanks in advance.
    Hans
  • Synthohol
    Certified Konica Expert
    • 5851
    Re: BH-363 dead
    ck your PMs
    • Hansoon
      • Sep 2007
      • 3391
      Re: BH-363 dead
      Cannot open the link
      Hans
      • Hansoon
        • Sep 2007
        • 3391
        Re: BH-363 dead
        OK, I found elsewhere the NVRAM reset thingy and used it. After a lot of different error codes, Chinese language indications in the display, many fault codes and finally the dreaded "License Error" machine is up and seems mechanically working but..........
        the display showing is the display of a color machine not as it should be B&W for a BH-363. Though the machine appears to work mechanically (prints come out solid black but that might have another reason yet) it is unacceptable to have this stupid color display in a mono machine. Obviously was my first impression right that someone, perhaps the wholesaler, messed up with the original NVRAM in this otherwise nice and very clean machine.
        Any ideas how to get rid of this display bungle?
        Hans
        • copier tech
          • 8179
          Re: BH-363 dead
          Hans
          Sounds like you used the wrong NVRam reset tool, maybe for the C360 etc?
          • Hansoon
            • Sep 2007
            • 3391
            Re: BH-363 dead
            That's what I am thinking but according to my information should it be "A1UD0Y0-F000-GQ7-D1(00)"
            This is what is mentioned in the accompanying description of KonicaMinolta and what I installed:
            "bizhub 423/363/283/223 Jig firmware GQ7-D1 A1UDOY0-F000-GQ7-DA(00).exe"
            Hans
            • copier tech
              • 8179
              Re: BH-363 dead
              Hans
              • Hansoon
                • Sep 2007
                • 3391
                Re: BH-363 dead
                Yep! See attached pictures.
                Spooky 363 20200719_105424.jpgSpooky 363 1 20200719_114554.jpgSpooky 363 2 20200719_105434.jpg
                Hans
                • copier tech
                  • 8179
                  Re: BH-363 dead
                  [ATTACH=CONFIG]46226[/ATTACH][ATTACH=CONFIG]46228[/ATTACH][ATTACH=CONFIG]46227[/ATTACH]
                  Hans
                  Very strange!
                  Try the correct mass production firmware again.
                  Also for the License management error try this:
                  1. Go to the service mode and change machine serial number to A0R6021006374 (must be uppercase)
                  2. Reboot the machine (turn off/on main power switch)
                  3. Go again to the service mode, then [STOP]->[9], then [License Management]->[Initialise]
                  4. Use following initialisation code: 2VRA4-UGGA2-Z2H4K-7AVUH-F58SW-J2Z7U-QVKVK
                  5. Reboot machine again
                  6. One more time go to service mode and set back your original serial number
                  7. Last reboot, and you should have no error
                    • 23009
                    Re: BH-363 dead
                    How bizarre! =^..^=
                    • femaster
                      • May 2011
                      • 1514
                      Re: BH-363 dead
                      I'm pretty sure there is a bitswitch that can be changed to fix that, but I don't recall what it is. I'll try to remember to ask at the office tomorrow, I know that have it documented somewhere...
                      • allan
                        RTFM!!
                        • 5462
                        Re: BH-363 dead
                        There was a B/W version of the C360...
                        Whatever
                        • copier tech
                          • 8179
                          Re: BH-363 dead
                          Really? Never seen one but I bet it was super reliable.
                          • tsbservice
                            Field tech
                            • 8026
                            Re: BH-363 dead
                            Hans
                            Wrong/Corrupted Movie data?
                            • emujo2
                              • Mar 2017
                              • 1579
                              Re: BH-363 dead
                              Although I could get behind the idea that a softswitch could enable/disable the color selection, what could be the possible reason to put a softswitch in for color selection on a B&W model. What does your printer config sheet look like? Generic or 363?
