Phantom Part Number? Cant find anywhere....
  • methogod
    • Dec 2008
    • 921
    Parts Guru's? Parts Masters?
    Looking to install a MIC-4150 on a 1250. Fiery came without the items in the photo. I need the VIDEO INTERFACE board, or they call it Relay Board with Bracket. I can 3D print the enclosure, and I can find a AC adapter.
    Def Buy Coffee, Beer or Weed (medical use only) for the right answer...
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    Re: Phantom Part Number? Cant find anywhere....
    [ATTACH=CONFIG]46482[/ATTACH]
    I've seen Kon/Min list some option items as supplies?
    What model fiery IC-???. Cant read your attachment, too small.
    Also try Hytech dealer services out of FL. They may have a surplus board to sell.
    • tsbservice
      Field tech
      • 8020
      I lost some time but can't find it. They say Fiery MIC-4150 comes with this interface kit but I was unable to source part numbers in any documentation.
      • wjurls
        • Feb 2017
        • 498
        Is this bigger? I've looked everywhere as well and can't find anything for it.
        • copiers01
          • Mar 2018
          • 23
          Hi,
          I lost Relay board with mounting bracket.
          The board is labeled with number 2 on page 17
          Does anyone know where I can buy the missing part?
          • emujo2
            • Mar 2017
            • 1579
            Very confusing..All my documents say this assy comes with the MIC 4150/Fiery 4150, but I do not see this assembly broken out in the parts books. Every part listed is for the Fiery itself.. This install guide shows this part being pulled from inside the Fiery and placed inside the back of the production machine..If no one pulled the interface board out of the old machine you are stuck and it looks like you need to order the entire Fiery again..E
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Are you sure it's not considered a sales item?
              I know that some brands will omit sales items from parts catalogs.
              Fieries just add a nasty layer of complexity.
              • allan
                RTFM!!
                • 5462
                Think like emujo mentioned it supplied as a complete kit.
                What about contacting EFI directly?
                Whatever
                • Synthohol
                  Certified Konica Expert
                  • 5847
                  nobody looked in the parts manual?
                  i believe you are looking for parts 13 and 18?
                  • methogod
                    • Dec 2008
                    • 921
                    Was told that it was to be removed and replaced with the interface board that came with the MIC4150.
                    • Albonline
                      • Sep 2008
                      • 1151
                      same thing only longer to extend. past panels
                      • emujo2
                        • Mar 2017
                        • 1579
                        Thought you might be on to something...but...the Fiery install guide has you remove this interface assy and replace it with the Fiery Assy. E
                        • Synthohol
                          • 5847
                          Sonofabitch.
                          Looked exactly like it.
                          I don't recall fierys coming with an interface kit in the box though.
                          It's not even listed on the MIC parts list.
                          • oscar
                            • May 2010
                            • 45
                            would you still have this MIC-4150 installation manual:
                            Originally posted by copiers01
                            Hi,
                            [ATTACH=CONFIG]48187[/ATTACH]
                            • methogod
                              • Dec 2008
                              • 921
                              I have given up on this project, if you need the black box that comes with the MIC4150 I have it. If you want the server i have it as well. msg me.
