Konica minolta bizhub C454e keeps jamming in the DF unit (Error 66-05)
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    #16
    Re: Konica minolta bizhub C454e keeps jamming in the DF unit (Error 66-05)
    Originally posted by Bix
    It is anxious to know that you could lose the spring. One day I'll try to take it apart too, but so far I have implemented another technique. I always clean by removing the inner cover. If we are talking about the same sensor, after removing the cover the sensor is disassembled with 2-3 screws (it is located on the left while on the right there is the output sensor).
    is it the same sensor?
    You can't lose the spring because it's attached to the ADF. It's sometimes difficult to grab it with needle-nose pliers or hemostats and place it back over the protrusion on the plate if you remove the plate completely. I've done this so many times, it's no big deal to just grab the spring and hook it back over the protrusion before screwing the plate back down.
    Yes, it's the same sensor and the other way to it is from above but you have to remove 10 screws for the cover/guide (part #A3CEPP4408 in the parts manual) just to gain access to it which is why I usually go at it from underneath. If I'm really cleaning the ADF, I'll go from above and then clean all the rollers and sensors under that 10 screw cover/guide while I'm at it since I already have it off.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
      • 23010
      #17
      The first time I took it out from the top. It is a lot of screws. I also noticed that particular guide can get significant paper cuts that can snag up your originals. But you do get a great view if the velvet pad below.
      • femaster
        • May 2011
        • 1514
        #18
        Originally posted by srvctec
        ...but you have to remove 10 screws for the cover/guide (part #A3CEPP4408 in the parts manual) just to gain access to it...
        Isn't that just a crazy number of screws considering what that plastic cover consists of!? Always thought that was a bit of overkill there. Especially on the DF-624, that plastic guide has 11 screws. Why!?
        • srvctec
          • Oct 2009
          • 827
          #19
          I'm pretty sure KM owns stock in screw manufacturers because in my almost 32 years of working on their stuff, that's one thing you can always count on- plenty of screws even when it seems totally unnecessary.
          • Bix
            • Apr 2018
            • 1421
            #20
            KM has always told me more screws = more solidity = less noise.
            But with iSeries it's not the same thing anymore. They understood that perhaps those screws are not really needed.
            • tsbservice
              Field tech
              • 8030
              #21
              More screws on thin metal sheets to prevent them wobble maybe
