Konica minolta bizhub C454e keeps jamming in the DF unit (Error 66-05)
  • Casian55
    • Jul 2019
    • 18
    [Jamming] Konica minolta bizhub C454e keeps jamming in the DF unit (Error 66-05)
    Hi everyone, I have 2 Konica minolta that keep jamming pages that I want to scan/print. It happens after a random number of pages, the page gets stuck half-way out the DF unit and it says error 66-05. It also shows position 25 that is directly under the DF unit. I have already tried to clean every roller, but it keeps happening. Manual says: "The original reading sensor (PS4) is not turned OFF after a lapse of a given time after the original registration sensor (PS3) is turned OFF (blocked)." I'm not sure that this could be the cause of thejamming..Is it worth to replace a sensor? What should I do?
  • allan
    RTFM!!
    • 5462
    Re: Konica minolta bizhub C454e keeps jamming in the DF unit (Error 66-05)
    You should do a sensor check in service mode and hope you can see the devious behavior by shaking stuff around.
    Never changed a sensor on these specific ones yet.
    Use the theory of operation or the parts manual to pinpoint the sensor.
    Could be that its the one you missed and its dirty or defective.
    I will not rule out worn out rollers.
    Whatever
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      How many clicks on the adf? If cleaning the following sensors:
      Registration sensor (PS3)
      Document reading sensor (PS6)
      and cleaning the rollers does not resolve the issue.....
      then just replace the ADF feed kit. It usually helps that 66-05 jam issue.
      Other stuff:
      Service mode sensor check- ensure all the sensors are working properly.
      Condition of the originals? Quality of paper being fed can cause many many many issues...
      Replace that feed kit. Part #: Konica Minolta DF-624MK, DF-628MK, DF-629MK, DF-701MK, DF-704MK
      • copier tech
        • 8190
        Sounds like you are an end user?
        Most likely the sensor is dusty highly unlikely its failing intermittently.
        • tsbservice
          Field tech
          • 8030
          PS3 is photosensor with actuator. Check for photosensor actuator free move.
          More likely PS6 which is reflective type photosensor is dirty or most likely its reflecting pad is full of paper dust. Of course depending on couters and cr.p paper originals they use you may need a new set of rollers.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            If it's works then jams if paper is flat it most probably just needs new rollers and a clean quite basic stuff if you not sure call a credited Konica Service engineer it will save you time and money in the long run
            Good luck
            Regards Mark
              • 23010
              For the 66-05 go directly for the document read sensor.
              Either it's dusty or the velvet pad below it is dusty. Pull down the guide at the left side of the white plate and there it is. Voila! =^..^=
              • copyman
                Owner / Technician
                • Sep 2005
                • 4736
                BC is referring to the DF-624 that has the spring loaded door that opens. Don't think this feeder used the DF-624? Almost certain C454e & C554e came with the dual scan DF-701 as standard feature.
                If it has the DF-701 leave top door open, lift adf and on underside push up on the white roller so you can spray air inside the crack on left side of roller you exposed by pushing up on white roller. Pay close attaention to the middle, spray that area really good. Also flip down green lever DF1 on underside of ADF and blow that exit area out real good with canned air.
                • blazebusiness
                  • 1257
                  You are correct. The c454e and c554e came standard with the dual scan adf. (DF-701). The dual scan adf was optional on the C224e,C284e,C364e copiers. They use the DF-624 or the DF-701
                  • occus
                    • 337
                    All of our 224e - 554e had the 66-05 jam. It is only dust. Clean the sensor. Push the DF upward and look at the sensor from below. There is a triangular hole.
                    It is important to use a flashlight to see the dust.
                    • femaster
                      • May 2011
                      • 1514
                      If you have a C454e, then wherever you got your jam code info from is wrong. J66-05: "The document reading sensor (PS6) is not turned OFF after a lapse of a given time after the registration
                      sensor (PS3) is blocked."
                      Lift up the ADF. On the Left side of the ADF, you will see a black plastic strip with a metal plate attached to it on the left side of the white "roller". There is a notch in the center (front to back) of this plastic strip (See Attachment). Inside that hole is the PS6 sensor, and across from it, attached to the black plastic, is a felt pad that you can not see. On this model of ADF, Konica Minolta decided it was a good idea to eliminate the ability to flip this open for cleaning, and decided that screwing it to the ADF was a better idea; they were WRONG. Take a can of compress "air" and blow out the inside area of this notch, and there is 98% chance that your jamming will stop.
                      • srvctec
                        Former KM Senior Tech
                        • Oct 2009
                        • 827
                        The problem with just shooting air in there is that the pad is never directly cleaned because of the limited access. I've just resorted to always removing the 3 screws on the metal plate (watch out for the grounding spring and how it goes back in place looped around the protrusion on the plate) and the 2 screws on the black plastic guide which will then give enough clearance to actually get the air stream onto the felt pad. I do this disassembly every single time I see the jam code is a 66-05 because I've gone behind other lazy techs that will NOT disassemble something to properly clean it and the code always comes back in short order. Sure, it takes a few extra minutes to disassemble but definitely solves the problem until the pad/sensor get dirty again in a few weeks/months.
                        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                        • femaster
                          • May 2011
                          • 1514
                          I do this myself as well. That disassembly can be a bit tricky with that spring attached to the metal plate if you've never done it before. Since this sounds like an end user with the problem, I felt it better to just have them blow it out. I'd hate for them to attempt to pull it apart and have that spring jump off the plate, as it can be a bastard to get back on.
                          • srvctec
                            • Oct 2009
                            • 827
                            Well crap, I didn't take into consideration that the OP is most likely an end user.
                            To the OP, if you're an end user, don't take it apart!
                            • Bix
                              • Apr 2018
                              • 1421
                              It is anxious to know that you could lose the spring. One day I'll try to take it apart too, but so far I have implemented another technique. I always clean by removing the inner cover. If we are talking about the same sensor, after removing the cover the sensor is disassembled with 2-3 screws (it is located on the left while on the right there is the output sensor).
                              is it the same sensor?
