Re: Konica minolta bizhub C454e keeps jamming in the DF unit (Error 66-05)
You can't lose the spring because it's attached to the ADF. It's sometimes difficult to grab it with needle-nose pliers or hemostats and place it back over the protrusion on the plate if you remove the plate completely. I've done this so many times, it's no big deal to just grab the spring and hook it back over the protrusion before screwing the plate back down.
Yes, it's the same sensor and the other way to it is from above but you have to remove 10 screws for the cover/guide (part #A3CEPP4408 in the parts manual) just to gain access to it which is why I usually go at it from underneath. If I'm really cleaning the ADF, I'll go from above and then clean all the rollers and sensors under that 10 screw cover/guide while I'm at it since I already have it off.
