Konica Software Switch settings (complete)
  • rrrohan
    • Sep 2011
    • 1977
    #31
    Re: Konica Software Switch settings (complete)
    Since I like my data in of Excel spreadsheets, I've gathered this information into a searchable .xlsx file ... if anyone is interested in the file. =^..^=
    i feel like some more advanced software switches arent made easily known because unless you understand what they do you could make things worse.
    I had to get my IT guy to explain what switch 219 was going to do and as it turns out wouldnt of helped in my case anyway
    • tulintron
      • Jul 2014
      • 669
      #32
      Originally posted by Synthohol
      where did you find that info?
      in a bulletin? i hate giving incomplete advice when i dont have/know all the sources of info.
      Ha ha ha ha.Jotunn helped me a few times.
      He has some cards up his sleeve.
      • D Colour
        • Oct 2008
        • 213
        #33
        Anyone? :O)
        Bit late to the party with this:
        I know its not the 8 series but:
        We have an old Olivetti D Colour MF452 Plus here and its equivalent Bizhub C454e
        Olivetti is set to 00, Konica is 02. Guess it is just under generic like Muratec as progoffice said.
        Everything that has a beginning, has an end.....
        • tulintron
          • Jul 2014
          • 669
          #34
          Have any of you already used the tool
          "Software_SW_Setting_Checking_Tool_v1"?
          There it seems to have all the functions of the sw software keys.
          • tsbservice
            Field tech
            • 7981
            #35
            True this is very helpful to compare if some soft switches are modified from default values.
            The question is what non service manual listed switches do. Very complex question though, it heavily depends on machine model, function version and firmware level.
            • JAGonzalez
              • Dec 2019
              • 1
              #36
              Good idea be nice if we can all chip in & fill in the blanks!
              These are a few i've picked up.
              71 Hide the colour copy option
              159 HEX 08 Keeps SSD from going to sleep causing freezing issues.
              172 HEX 05 Hide Marketplace app
              Hi coleage
              which value must be for 71 Hide the colour copy option?
              Thanks a lot
              • kopirky.org
                • Mar 2018
                • 2
                #37
                SW 153
                - HEX 40 old color reproduction
                - HEX 00 new color reproduction (default)
                • allan
                  RTFM!!
                  • 5462
                  #38
                  55 is no stop option HEX 0C?
                  127 show consumable life HEX 00?
                  Can someone confirm?
                  Whatever
                  • kopirky.org
                    • Mar 2018
                    • 2
                    #39
                    Yes. I use 51:F0 (drum, developing) and 55:0C (fuser, belt).
                    Yes. It is disabled by default on C227 127:04. You can also enable/disable showing life in the service mode - unit change.
                    • Brett GS
                      • Jun 2013
                      • 154
                      #40
                      Hi Blackcat
                      I would like to get it from you if offer still stands
                      I like keeping any helpful info at hand.
                      • tsbservice
                        Field tech
                        • 7981
                        #41
                        It's maybe typo but soft switch is 227.
                        • allan
                          RTFM!!
                          • 5462
                          #42
                          Thanks yes my bad.
                          Whatever
                          • zayonc
                            • Jan 2022
                            • 48
                            #43
                            "050 - ACS mode can be changed to limit the amount of time that the color IUs run. When the new mode is selected, the printer works as though doing monochrome printing without driving the color IUs."
                            What should be the value?
                            • allan
                              RTFM!!
                              • 5462
                              #44
                              How is life in Kharkiv? Hope all is well.
                              First there is Engine firmware dipSW 25 that is OFF for production priority and ON for parts life priority. In the OFF state the primary transfer rollers never retracts* for ACS copy or Auto Color for print if the job is mixed B\W and color. In the ON state it will retract if a given number of consecutive B/W pages was detected but only after the second set for copy mode. It needs to get the histogram data from the first set but it does not wait and starts printing immediately without knowing if the pages in the first set are B/W or color.
                              ACS needs 4 or more consecutive B/W pages to switch to K rotation only and always starts in CMYK rotation for the first 3 pages regardless if they where B/W. Base on 45ppm.
                              SW 50 HEX00 : Production priority (less print interruption)
                              SW 50 HEX01 : Parts life priority (more print interruption)
                              So Engine firmware dipSW 25 to ON and SW 50 HEX01. The machine will be slower with interruptions in the print job.
                              The machine is default set to Engine firmware dipSW 25 to OFF and SW50 does not seem to apply?!
                              Whatever
                              • rrrohan
                                • Sep 2011
                                • 1977
                                #45
                                Disable users from changing trays paper type
                                software switch 245 to 02
