Konica Software Switch settings (complete)
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    I would love to know what all the software switch settings do. Does anyone have a more or less definitive list of all the standard Konica Software switch meaning for Technician's quick reference? Depending on the model/service manual the switch info available is very meager.
    To get this started see the 8 series switch settings below for example:
    Konica Software Switch Settings (8 series)
    01
    02
    03
    04
    05
    06
    07
    08
    09
    10
    11
    12 Addition of Authentication Device
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25 FW Version Function Setting
    26
    27
    28
    29
    30
    31
    32
    33 Renders some functions which were available when both administrator authentication and key counter were provided with when using the vendor , available only with admin authentication
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49 Upper limit of copies that can be input through the control panel setting
    50
    51 Settings for Life warning/replace display of units
    69 When printing using manual bypass in custom size allows for printing only with a print driver ------- settings
    70 Alarm sound and screen display for communication errors due to CSRC causes
    72 Import/Export function of the address book through usb memory
    121 Operation when a double feed is detected when adf is used
    124 Function to restrict the file type of TX fax
    135 Setting for the ID length of the HID Prox card
    143 Expansion setting of the touch panel sensitive area when web browser function is used
    145 Switching to auto detection for paper size in manual bypass tray
    146 Setting for enabling use of non image area erase ,centering, and original size when book original is used in fax/scan mode
    151 Setting for displaying or hiding the near empty display time
    152 The email body print settings of the email RX print
    155 Validation/invalidation of the debug setting of the log
    157 Low Power Mode Settings
    163 Setting for the auto execution of self diagnosis (full)
    192 Sets whether to enable Android or iOS function
    203 Setting to automatically change login authorization to a second user when the second user
    attempts card authentication after a first user has been authenticated through card authentication
    206 Setting whether to enable coverage counter
    227 Setting for the display of consumable level and warning (Operatino panel,PSWC,Fiery)
    230 Setting for the display of consumable level and warning (PSES,MIB,PrintFleet,SiteAudit)
  • copier tech
    • 8196
    Re: Konica Software Switch settings (complete)
    01
    02
    03
    04
    05
    06
    07
    08
    09
    10
    11
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    26
    27
    28
    29
    30
    31
    32
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    50
    Good idea be nice if we can all chip in & fill in the blanks!
    These are a few i've picked up.
    71 Hide the colour copy option
    159 HEX 08 Keeps SSD from going to sleep causing freezing issues.
    172 HEX 05 Hide Marketplace app
    • progoffice
      • Nov 2008
      • 337
      Switch 10 Hex 2 will make a Generic (Muratec) a Konica. This is important when it comes to drivers picking up all device options, paper tray information and accepting authentication account track information if current "Generic" drivers aren't available. We sell both, but sometimes Muratec doesn't release drivers fast enough for equipment they offer. We just installed a Muratec C5595i and had to do this so we could use the Konica C550i drivers. Muratec hadn't released them yet.
      • Synaux
        • Mar 2012
        • 1224
        A lot of the time I can get much more detailed information by searching through the All Active Solutions document(s). Search for HEX, DIP, software switch, etc.
        Sadly, I do not have it for this model or I would have posted my findings (would be nice to have if someone is in a giving mood).
        • blazebusiness
          • 1257
          It is my understanding that there is now no All Active Solutions for the current models. Konica has discontinued that and just relies on Tech bulletins and Knowledgebase.
          If you ever need the older All Active Solutions stuff just PM me and I will be glad to send you a download link.
          Thanks for the input guys..keep it coming and I will add it to the list..see updated list with your inputs below:
          10 Hex 02 makes a generic (Muratec) a Konica important so drivers can pick up all device options
          71 Hide color copy option
          159 Hex 08 keeps SSD from going to sleep causing freezing issues
          172 Hex 05 hide marketplace App
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            I thought it was 172 to 01 to remove Marketplace. At least that's what we've been doing after getting that info somewhere here on CTN.
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
            • blazebusiness
              • 1257
              Just listing what information copier tech was nice enough to post. Perhaps he will clarify the info.
              • copier tech
                • 8196
                Yes so SW 172 HEX 05 is the default HEX 01 hides the Marketplace app.
                • blazebusiness
                  • 1257
                  [ATTACH=CONFIG]46785[/ATTACH]
                  OK then---so the latest software switch updated list:
                  (and keep that new switch info coming guys!)
                  Konica Software Switch Settings :
                  10 Hex 02 makes a generic (Muratec) a Konica important so drivers can pick up all device options If you want to turn any Develop model into a Konica, you should put switch 10 into 02, not into 00.
                  50 ACS mode can be changed to limit the amount of time that the color IUs run. When the new mode is selected, the printer works as though doing monochrome printing without driving the color IUs.
                  73 Hex 01 - This setting should allow you to hold scan settings and to be able to use the same address without touching the OK button after every job
                  172 Hex 01 marketplace App is hidden ------Hex 05 is the default / marketplace App installed
                  • Synaux
                    • Mar 2012
                    • 1224
                    Seriously?! Those documents have saved me so much time over the years. Not to mention the numerous times I stumbled across issues/fixes I would never have been aware of otherwise. This saddens me.
                    • blazebusiness
                      • 1257
                      I heard that it was discontinued from some other technicians and would love to be wrong about that. Could someone confirm all active solutions is still a thing on the newer models.
                      • srvctec
                        • Oct 2009
                        • 827
                        It was still a thing a couple months ago. They were getting updated nearly daily and I'd download all the new ones for all the current machines about once a month but it's been a couple months since I last did it. I'd much rather have a pdf file on my phone vs. having to try and get a signal in some of the small towns I go to with no cell service. I've been that way since the solutions pdf files started and probably won't change.
                        • blazebusiness
                          • 1257
                          Nice. That’s reassuring then.....can’t believe everything you hear from the rumour mill.
                          • femaster
                            • May 2011
                            • 1519
                            I can confirm they are still going strong in the US anyway. Just looked up a random model from each of the series over the last few years, and found an All Solutions file for each model I looked up: C552, 232, C224e, C258, C659, and a C300i. All of them looked as if they had been updated within the last couple weeks, most were within the last week.
                            • copier tech
                              • 8196
                              Can we keep this thread going!?
                              I need to know what HEX setting for SW10 is for Olivetti ?
