Konica Software Switch settings (complete)
  • copier tech
    • 8196
    #16
    Re: Konica Software Switch settings (complete)
    Can we keep this thread going!?
    I need to know what HEX setting for SW10 is for Olivetti ?
    Anyone? :O)
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      #17
      Anyone? :O)
      Model number? 10 on Konicas depending on which bit switch - Hex 00 is probably to specify time zone settings and Hex 20 for how many fax reception rings before answering.
      • kingarthur
        • 1385
        #18
        Originally posted by femaster
        I can confirm they are still going strong in the US anyway. Just looked up a random model from each of the series over the last few years, and found an All Solutions file for each model I looked up: C552, 232, C224e, C258, C659, and a C300i. All of them looked as if they had been updated within the last couple weeks, most were within the last week.
        I haven't seen these in the UK for donkeys years, anyone know if they're still available here.....and whereabouts they are...
        • tsbservice
          Field tech
          • 8048
          #19
          Those are available in NA area, you should have MKM account not Infohub, Knova etc.
          • zeke
            • Aug 2021
            • 1
            #20
            Originally posted by blazebusiness
            It is my understanding that there is now no All Active Solutions for the current models. Konica has discontinued that and just relies on Tech bulletins and Knowledgebase.
            If you ever need the older All Active Solutions stuff just PM me and I will be glad to send you a download link.
            Thanks for the input guys..keep it coming and I will add it to the list..see updated list with your inputs below:
            Konica Software Switch Settings
            10 Hex 02 makes a generic (Muratec) a Konica important so drivers can pick up all device options
            12 Addition of Authentication Device
            25 FW Version Function Setting
            33 Renders some functions which were available when both administrator authentication and key counter were provided with when using the vendor , available only with admin authentication
            49 Upper limit of copies that can be input through the control panel setting
            51 Settings for Life warning/replace display of units
            69 When printing using manual bypass in custom size allows for printing only with a print driver ------- settings
            70 Alarm sound and screen display for communication errors due to CSRC causes
            71 Hide color copy option
            72 Import/Export function of the address book through usb memory
            121 Operation when a double feed is detected when adf is used
            124 Function to restrict the file type of TX fax
            135 Setting for the ID length of the HID Prox card
            143 Expansion setting of the touch panel sensitive area when web browser function is used
            145 Switching to auto detection for paper size in manual bypass tray
            146 Setting for enabling use of non image area erase ,centering, and original size when book original is used in fax/scan mode
            151 Setting for displaying or hiding the near empty display time
            152 The email body print settings of the email RX print
            155 Validation/invalidation of the debug setting of the log
            157 Low Power Mode Settings
            159 Hex 08 keeps SSD from going to sleep causing freezing issues
            163 Setting for the auto execution of self diagnosis (full)
            172 Hex 05 hide marketplace App
            192 Sets whether to enable Android or iOS function
            203 Setting to automatically change login authorization to a second user when the second user
            attempts card authentication after a first user has been authenticated through card authentication
            206 Setting whether to enable coverage counter
            227 Setting for the display of consumable level and warning (Operatino panel,PSWC,Fiery)
            230 Setting for the display of consumable level and warning (PSES,MIB,PrintFleet,SiteAudit)
            i never gave you this, here is a exert from the service Manuel for software switches and what they do (hopefully file attached)
            • Gaffers01
              • May 2011
              • 335
              #21
              Just had a second-hand C308, that every time I did anything in the Utility Mode I had to put the admin password in and after some digging came across this.
              Password Protect The Utility Button
              It is now possible to password protect the Utility Button on the Main Screen of the MFP.
              This is useful in Multi User Environments to prevent unauthorised access to Utility, User Settings, Device Information, One Touch/ User Box Registration, Consumable Life, Banner Printing, Remote Panel Operation and so on.
              With this set, the User will be prompted for a password when pressing the Utility Button - (The Password is the same as the Password used to access the Admin Mode).
              Setting Procedure:
              Access Tech Rep / System 2 / Software SW Setting:
              Password protect access to Utility mode.
              Software SW No.200 Hex 00 : Disabled (default)
              Software SW No.200 Hex 20 : Enabled
              This SW is available for the following models:
              • All A3 "E series" devices (Must be on latest Firmware and Function Version)
              • All A3 7 and 8 Series Devices
              **Note - None e series devices are NOT supported**
              Related Topic: Password protect the User Settings Menu
              Should you wish to just protect the User Settings Menu, this can be done by setting SW 71 to Hex 08
              • rrrohan
                • Sep 2011
                • 1977
                #22
                What's switch 219 hex 08 do?
                Sent from my Pixel 4 XL using Tapatalk
                • tmmdmmm
                  • Apr 2021
                  • 173
                  #23
                  Is there even a hex 08? All I know of is 00/04
                  • rrrohan
                    • Sep 2011
                    • 1977
                    #24
                    KM support told me to use hex 08 for a fault but didnt say what it did. hex def goes past 04 consider function versions goes as far as B0
                    • Synthohol
                      Certified Konica Expert
                      • 5888
                      #25
                      Software SW No.219 0x00: SMB1.0/2.0 are available. (default)
                      Software SW No.219 0x04: Only SMB2.0 is available.
                      change ntlm to smb 2 as well.
                      hex 08 is not a valid option.
                      • jotunn
                        • 634
                        #26
                        Software SW No.219 0x08: Support for DHCP option 81
                        • rrrohan
                          • Sep 2011
                          • 1977
                          #27
                          Ok thanks, yes it's a DNS issue regarding email only working on IP not hostname so the advise makes sense
                          • Synthohol
                            • 5888
                            #28
                            where did you find that info?
                            in a bulletin? i hate giving incomplete advice when i dont have/know all the sources of info.
                            • jotunn
                              • 634
                              #29
                              PM
                                • 23010
                                #30
                                Since I like my data in of Excel spreadsheets, I've gathered this information into a searchable .xlsx file ... if anyone is interested in the file. =^..^=
