Konica Software Switch settings (complete)
+ More Options
Posts
  • copier tech
    • 8132
    #46
    Re: Konica Software Switch settings (complete)
    Originally posted by rrrohan
    Disable users from changing trays paper type
    software switch 245 to 02
    Thanks, this is another good one to add to the list I needed it just last week.
    • Reed
      • Feb 2011
      • 259
      #47
      Originally posted by progoffice
      Switch 10 Hex 2 will make a Generic (Muratec) a Konica. This is important when it comes to drivers picking up all device options, paper tray information and accepting authentication account track information if current "Generic" drivers aren't available. We sell both, but sometimes Muratec doesn't release drivers fast enough for equipment they offer. We just installed a Muratec C5595i and had to do this so we could use the Konica C550i drivers. Muratec hadn't released them yet.
      If you do this be aware that the IP address may change. I have done this several times on a machine that has been installed and each time the IP address changed to DHCP. I had to go into the network and manually enter the correct IP address
      • tmmdmmm
        • Apr 2021
        • 173
        #48
        You waited until after I left the industry to post this one?!?!?!?!
        • rrrohan
          • Sep 2011
          • 1977
          #49
          when you quit the beacons were lit and i knew it was time to announce it
          • strider5555
            • Jun 2008
            • 96
            #50
            Here is another one to add. Software SW 24 Hex 01, prevents machine from printing a blank page on custom PCL print job because of a form feed command. Works on everything from C220\C452 series up to I series.
            Blank Page in Custom PCL print data stream.pdf
            • elmaligno
              Expert technician KM
              • Oct 2009
              • 302
              #51
              That item does not work
              Field technician since 1994
              • rrrohan
                • Sep 2011
                • 1977
                #52
                only i series and has to be latest Firmware. its a new switch
                • tsbservice
                  Field tech
                  • 7975
                  #53
                  DipSW No.243(bit 0)
                  The function to add the name of the login user to the head of the Scan file name when scanning.
                  0x00:disable(default)
                  0x01:enable
                  • screwdriverassy
                    • Sep 2018
                    • 16
                    #54
                    On color DinA4 machines, old bizhub C3350 (not "i" suffix), changing between "KM" or "Generic":
                    Software Swith Setting No. 13
                    hex 08 Generic.
                    hex 04 Konica Minolta.
                    bizhub C3350 software switch for "Generic" <-> "KM"?
                    • copier tech
                      • 8132
                      #55
                      Is there a SW to disable the media detect sensor on the C650i ?
                      I have a device with 80gsm loaded but it keeps switching the trays to 120gsm.
                      • jotunn
                        • 606
                        #56
                        You can disable paper type sensing:
                        PSWC > Administrator > System Settings > Auto paper detection setting (or "Paper type auto detection settings.") > ON/OFF
                        * This setting is displayed when the device is equipped with the option [IM-102: Intelligent media sensor].
                        But also you can try to make weight calculation again:
                        ■ Weight calculation default settings
                        (1) Display the Service Mode screen.
                        (For details of how to display the Service Mode
                        screen, see the service manual.)
                        (6) Touch the Start key.
                        • copier tech
                          • 8132
                          #57
                          Thank you for this info I will check this setting next time i'm on site.
                          I also found out SW83 disables the media sensor but the service manual doesn't state what the HEX setting should be.
                          Disable Media Sensor SW83.pdf
                          • tsbservice
                            Field tech
                            • 7975
                            #58
                            [ATTACH]55423[/ATTACH]
                            Are sure that Engine FW DipSW has HEX value? Back to the learning board then. They are all On or Off.
                            P.S.
                            Nevertheless you may nail it, just highlight it and reboot the machine.
                            • copier tech
                              • 8132
                              #59
                              P.S.
                              Good point, may this is an engine switch not software SW.
                              • domovoi3333
                                • Apr 2021
                                • 6
                                #60
                                Good idea be nice if we can all chip in & fill in the blanks!
                                These are a few i've picked up.
                                71 Hide the colour copy option
                                159 HEX 08 Keeps SSD from going to sleep causing freezing issues.
                                172 HEX 05 Hide Marketplace app
                                Hi guys,
                                what is HEX for dpsw 71 and 33
