Konica Software Switch settings (complete)
  • jotunn
    • 634
    #61
    Re: Konica Software Switch settings (complete)
    33 00000000 00
    33 00000001 01 Renders some functions, whichwere available when both administrator authentication and key counter were provided with when using the vendor, available only with administer authentication. Available only with administrator authentication
    33 00000010 02 To use DipSW of " When the vendor device is off, job cancel timing is selectable with "immediately" or "after job completion". " in Vendor2 mode. after job completion
    33 00000100 04 When setting to vendor 2, make transfer fax function available. Enabled
    33 00001000 08 Allow/ Prohibit Web print when using Vender2. Prohibit
    33 00010000 10 Enables or disables the automatic tray switching function when the vendor is installed. Enabled
    33 00100000 20 Enables or disables the function that enables the box function when setting the key counter I/F vendor. Enabled
    33 01000000 40 Enables or disables the Real Mode Twain function when setting the vendor or management device. Enabled
    33 10000000 80
    71 00000000 00
    71 00000001 01 In the "Counter" screen, a total counter can be added at the top of the screen besides the left four counters. Enabled
    71 00000010 02 Enable/Disable the ability to hide color-related keys.
    71 00000100 04 Function that hard copies can not be seen by others after a print error Enabled (To make hard copies unavailable to others: Disabled browsing)
    71 00001000 08 To display the screen that asks a password, when logging to the user settings Enabled
    71 00010000 10 In the utility menu, after meter count is pressed , then check details is pressed,
    the print list in the serial number screen is pressed, the administrator password screen is displayed.
    Enabled
    71 00100000 20 Hide Destination Type strings (eg. E-mail, SMB, FTP) on destination buttons in Scan/Fax Address Book. Enable
    71 01000000 40 Enable/Disable the function that allows setting only files that can be encrypted during Scan.
    71 10000000 80 Disable Public User deleting a job on the operation panel. Enabled (Public User cannot delete the job)
    • domovoi3333
      • Apr 2021
      • 6
      #62
      Originally posted by jotunn
      33 00000000 00
      33 10000000 80
      71 00000000 00
      Enabled
      • Toxic
        • 698
        #63
        What could be the reason i can not change dipsw 227 to 80 - fix, to hide consumables status, it revert back to 00.
        I see that today on ineo +227
        • elmaligno
          Expert technician KM
          • Oct 2009
          • 302
          #64
          you need to have the firmware updated
          Field technician since 1994
          • tsbservice
            Field tech
            • 8048
            #65
            Try 08 instead 80. Those 227 and 230 switches are either 00/08/48/80 in most models. As manual is often wrong about values I sometimes play with them until machine accept value and then check the outcome
            P.S. Happy holidays!
            • joe0705
              • Feb 2023
              • 4
              #66
              How to enable toner status counter ?
              • rrrohan
                • Sep 2011
                • 1977
                #67
                hiding consumable counts doesnt work on 4 series. so the original 227 might not be compatible neither
                • tsbservice
                  Field tech
                  • 8048
                  #68
                  afaik it should work on 4e.
                  • strider5555
                    • Jun 2008
                    • 96
                    #69
                    Here is a bulletin with all the intelligent yield control settings and models it works with. For the B227 it must have G3 or newer firmware, Function version 3.2. On 4/4e models it only works when connected to Vcare.
                    • jotunn
                      • 634
                      #70
                      For C224e series, hiding consumables button works for sure. Just use latest mass production firmware (probably even earlier would work as well) combined with function version 7 DipSW setting.
                      It's just a subset of the larger set of functions called "Intelligent Yield Control". With Intelligent Yield Control you let the machine to manage it's own consumables, and usually you wish to hide the button so the customer doesn't bother you with misleading (stupid) phone calls.
                      This is one, and the only function of DipSW 227-80 and DipSW 230-08.
                      227 10000000 80 Hide consumables statuses function (Hide on the Panel and PSWC)
                      230 00001000 08 Hide consumables statuses function (Block MIB information of consumables to applications and so on.)
                      @tsbservice
                      DipSW 227-48 probably can give you "Deleting temporary scan data function" and "The character array of the keyboard is changed from French to Canadian French."
                      DipSW 230-40 "Prevent sending to wrong destinations inadvertently when broadcast transmission."
                      • joe0705
                        • Feb 2023
                        • 4
                        #71
                        • Synthohol
                          Certified Konica Expert
                          • 5888
                          #72
                          the 284e has the toner gauge in the upper right corner, no gas gauge screen except maybe on PSWC.
                          • setfree49
                            • Dec 2022
                            • 3
                            #73
                            What is Engine FW DipSW 19 for? Got a C368 on GCH-X4 latest base firmware.
                              • 23010
                              #74
                              The documents that I have do not say specifically, but there are 10 possible settings for that switch: 00, 01, 02, 03, 04, 80, 81, 82, 83, 84.
                              How brave are you? The worst possible outcome would be ... say, changing the display language to Indonesian, and being unable to reverse it. =^..^=
                              • tsbservice
                                Field tech
                                • 8048
                                #75
                                He-he I certainly appreciate your thoughts Sir
                                Reminded me doing firmware update on Brother machine with black touch screen but responsible.
                                It was interesting, but after uploading successful main firmware it restarted as it should and same for sub firmware. Nevertheless nothing helped but main board .
