Restart 454e
  • Gift
    • Mar 2011
    • 2459
    Re: Restart 454e
    Is the battery on the controller board OK? I've seen some dying on the xx4e series leading to several issues, like data lost (counter "0").
    Edit: I think the voltage should be arund 3.3V
      • 8132
      Re: Restart 454e
      Interesting, we are always getting 'asked' how to clear the 4e series counters, so simply removing the battery will do the trick!?
      • Gift
        • Mar 2011
        • 2459
        Re: Restart 454e
        Yeah it might but I never tried to force it that way. I had a case with complete data loss after the machine was unplugged during a preventive maintanance and another case when we swapped a unit and powered it on when it arrived in our workshop for inspection and a "normal" data clear due to privacy protection.
        • uzi mana
          • Jun 2012
          • 20
          #19
          Re: Restart 454e
          Anyone know what to do?
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            #20
            Re: Restart 454e
            You still haven't mentioned whether you've done a Clear All Data in service mode as suggested by tsbservice in post #11. You replied to him with a completely different answer like you didn't even think his suggestion had merit. Maybe you just overlooked it or didn't get what he said or maybe there is a language barrier?
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
            • uzi mana
              • Jun 2012
              • 20
              #21
              Re: Restart 454e
              yes i did it and dont help
              • Gift
                • Mar 2011
                • 2459
                #22
                Re: Restart 454e
                battery check?
                • uzi mana
                  • Jun 2012
                  • 20
                  #23
                  Re: Restart 454e
                  battery check?
                  I checked
                  3.2 v
                  • Gift
                    • Mar 2011
                    • 2459
                    #24
                    Re: Restart 454e
                    If you really tried everything suggested here it's hard to tell how to proceed, especially if there's no chance for the sales guy to sell a new MFP and write this one off
                    Have you tried swapping any boards/electrical components so far, like PSU, MFP board, operation panel? Perhaps you have a part donator for stripping some stuff.
                    • uzi mana
                      • Jun 2012
                      • 20
                      #25
                      Re: Restart 454e
                      I have not tried it yet
                      Strange it happens to me in 2 machines same problem
                      I need to get another machine to replace parts like PSU or MFP
                      • femaster
                        • May 2011
                        • 1485
                        #26
                        Re: Restart 454e
                        Even just shorting the battery for a few minutes works. I have seen it cause other issues though, which requires a re-shorting of the battery, or reset firmware to bring it back to life.
                        • allan
                          RTFM!!
                          • 5462
                          #27
                          Re: Restart 454e
                          Shorting the battery that keeps the SSD running is a bit risky in the field. Like you said don't know the weirdness that can follow.
                          3.2V is close enough to correct should be 3.3V regulated.
                          Measure on a working machine anyway.
                          Whatever
                          • uzi mana
                            • Jun 2012
                            • 20
                            #28
                            Re: Restart 454e
                            even just shorting the battery for a few minutes works. I have seen it cause other issues though, which requires a re-shorting of the battery, or reset firmware to bring it back to life.
                            o.k
                            i try it and tall you if it is working
                            ty
                            • tsbservice
                              Field tech
                              • 7990
                              #29
                              Re: Restart 454e
                              o.k
                              ty
                              Don't do that. You may have luck but you may also turn the machine into a boat anchor.
                              • uzi mana
                                • Jun 2012
                                • 20
                                #30
                                Re: Restart 454e
                                o.k
                                but What to do?
