C6100 Installation - DIY or Hire Pro?
  • reckless
    • Feb 2017
    • 188
    Re: C6100 Installation - DIY or Hire Pro?
    The original equipment is new in boxes/crates minus the PB-503.
    The C6000 that was installed in less than 2 hours we used with 100k copies on it. It was installed 5-7 years ago.
    I didn't buy the machine from a dealer as it would have cost me 10x more.
      have you checked the cartons for setup/assembly instructions? they usually send them with the machines. along with ownership/warranty papers.
      • reckless
        • Feb 2017
        • 188
        No, just have a printout of colors being calibrated and 138 sheets on the counter.
        The PF-707M looks easy enough to hook in, not sure on the RU-518 but the PB-503 has me scared. If possible we would like to print this without the PB-503 and output on output tray on RU-518 but it doesn't look like KM system configurator allows that.
          • 22999
          #19
          This is totally impossible regarding install main unit options and calibrations tests.
          Wait for a tech willing to apply in your request.
          This is a days work. A setup done in two hours is shoddy work indeed. Count me out. =^..^=
            if you haven't purchased the manual yet.. put a request in here: https://www.copytechnet.com/forums/s...nual-requests/
            you might be able to hire a local tech if you put a request here: https://www.copytechnet.com/forums/employment/
            • reckless
              • Feb 2017
              • 188
              #21
              yeah i put a request there many months ago. Not finding someone...
              Copier Tech Needed in Chicago
              was considering posting a remote work request. We can do all the work and a professional oversee everything for a reasonable fee.
              Thanks put a post asking for the service manual!
                yeah i put a request there many months ago. Not finding someone... was considering posting a remote work request. We can do all the work and a professional oversee everything for a reasonable fee.
                A service tech would spend more time watching you fumble around than actually setting it up himself.
                • wjurls
                  • Feb 2017
                  • 494
                  #23
                  There has to be an Independent in greater Chicago that is familiar with KM Production machines. Keep looking. I would suggest asking Adil at Galaxy Copiers if he knows anyone in your area (626)400-6639.
                  I'd be happy to help if you were in Southern California.
                  • JR2ALTA
                    • Feb 2010
                    • 2030
                    #24
                    $1,500 - 2,000 dollars?!
                    Why wouldn't a Konica dealer just charge you their hourly rate? Usually 150 an hour maybe 200 in Chicago..
                    • reckless
                      • Feb 2017
                      • 188
                      #25
                      Thanks Adil is a nice guy. I have bought supplies from him in the past. I reached out to him and left a voicemail.
                      • reckless
                        • Feb 2017
                        • 188
                        #26
                        Due to getting run around from kmbs dealers we are going to attempt this ourselves. My warehouse guys have helped previously connect a production machine and did say it was a huge pain the butt as cables/ribbons are very, very short. They will be careful not to break anything and if we get nowhere will hire km on an hourly basis.
                        Does anyone know if there are installation manuals or youtube videos to help with install? I found this one for a c1070, how much different can c6100 be?
                        I love his videos, he explains alot of things so effortlessly
                        • reckless
                          • Feb 2017
                          • 188
                          #27
                          I'd be happy to print duplex with no finisher like he does here for time being (20:26 mark)
                          Is it possible to print with no finisher attached just relay unit RU-518 + pf-707m? Somehow lining up the finisher has me most afraid. The paper feeder and relay unit look easier.
