4 series, Engine DipSW to reset toner to full
  • rrrohan
    • Sep 2011
    • 1971
    4 series, Engine DipSW to reset toner to full, is this possible. I cant recall if this is only on 8 series and newer. If it is possible could someone please remind me of the
  • tsbservice
    Field tech
    • 7635
    Re: 4 series, Engine DipSW to reset toner to full
    Not possible on 4/4e series as far as I know. What problem you have?
    • Bix
      • Apr 2018
      • 1421
      It often happens to me that the toner is almost finished when it is actually full or vice versa. I wait for the printer to stop due to low toner, remove and reinsert the toner tube to return to 100.
      • rrrohan
        • Sep 2011
        • 1971
        Customer used non genuine toner and it was changed early. Was gonna see if I could just force it to report full but I'll just tell him to ignore it.
        Sent from my Pixel 4 XL using Tapatalk
        • gere1
          • Oct 2018
          • 20
          for series 4 dipsw1 resets all toner
          • tsbservice
            Field tech
            • 7635
            You mean all 4 toners?
            • gere1
              • Oct 2018
              • 20
              yes the 4 tonerIt usually does well but I have had some equipment that does not reset it
              • allan
                RTFM!!
                • 5445
                Question is what else does that reset?
                Whatever
                • gere1
                  • Oct 2018
                  • 20
                  just the tonerWhat else do you want to restore?I use google translator to see if I do not understand the question well
                  • wjurls
                    • Feb 2017
                    • 461
                    I wonder if that switch will work on my truck too? Change a dip switch and boom! Full tank!!
                    • tsbservice
                      Field tech
                      • 7635
                      It should...plus antifreeze, engine oil and brake fluid to make them 4
                      • Copier repairman
                        • Aug 2019
                        • 85
                        I have DIPSW enabled on the 4 series.
                        I ran DIPSW1, but the toner was not full.
                        • copier tech
                          • 7931
                          This option is not available on the 4 series.
                          Simply remove all the toners, run a print run, when the copier calls for a toner refit the used ones this will reset the toner life count.
                          • Synthohol
                            Certified Konica Expert
                            • 5463
                            ...Simply remove all the toners, run a print run, when the copier calls for a toner refit the used ones this will reset the toner life count.
                            thats been my "cheat" for years!!
                            • copier tech
                              • 7931
                              Yup, happens when the clients replace the toner before the copier calls for it.
