BH650i half black copies
  • mascan42
    • Oct 2008
    • 486
    OK, this is a bizarre one. I'm getting this defect only when copying off the glass. Prints are fine, coping through the doc feeder is fine. But all copies off the glass look like this. Sounds mechanical, right? But the defect is very clearly digital. The black area has a jagged edge, there are indents and grey areas at the edge. It's not even in a straight line.
    I've reseated connectors and replaced the CCD unit. The self-diagnostic comes back all OK. The mirrors are all secure and in their proper places. The carriage moves without any issues, and the lamp stays on for the entire scan.
    Everyone I've spoken to is stumped. And since it's a brand new machine, it's probably getting sent back next week. But I'd love some insight into WTF this could be.
  • GIUBOSS
    • 1437
    Re: BH650i half black copies
    [ATTACH=CONFIG]48098[/ATTACH]
    Trivial question, no error code? You have already contacted Minolta for any anomalies (or technical bulletins) already reported by other dealers or to have electronic boards to test on the machine. I didn't think you could replace the whole machine in these cases.
    • Woxner
      • Jul 2011
      • 853
      Ck for 8 series bulletin on this simular problem
      • rrrohan
        • Sep 2011
        • 1977
        Try grabbing under front left corner of scanner bed and lifting it. A few times and re test to see if it helped at all
        Sent from my Pixel 4 XL using Tapatalk
        • tsbservice
          Field tech
          • 8056
          Looks like mirror out of his place.
          • allan
            RTFM!!
            • 5462
            Just for entertainment try making reduced and enlarged copy and check if the defect also reduces and enlarges.
            Try covering the entire scanner with a box or a refuge bag and see if that makes any difference.
            Another thing to play with would be the scanner start position under copy area adjustment if i can remember that correctly.
            Whatever
            • mattcoop11
              • Jun 2015
              • 12
              • Brett GS
                • Jun 2013
                • 154
                Had something almost the same on a c308 and c558 and both it was mirror 3 that needed slight adjustment with a allen key.
                • copytechman
                  • Nov 2008
                  • 968
                  I had a c654e with something like that and it was one of the "pads" under the front mirror carriage that decided it wanted to do its own thing causing the carriage to have a bit of a tilt.
                  Just my 2c
                  A.
                  • mascan42
                    • Oct 2008
                    • 486
                    This wound up being the problem. No idea how it makes it out of the factory and through the warehouse pre-install procedures without anybody noticing.
