KM C280 print quality problem
  • Lakatom
    • Jan 2021
    • 8
    Hello there,
    By default, the printer does the following problem:
    If i swap the Cyan drum for Magenta drum:
    i don't understand the logic, could anyone explain?
    Yours sincerely, Lakatom
  • CP-1015
    • Nov 2020
    • 323
    Re: KM C280 print quality problem
    How are the Level Histroy values for cyan and yellow?
    If ok new blades for cyan and yellow else new drums.
    • wjurls
      • Feb 2017
      • 498
      What are the drum counts? Are they near or past yield?
      • Hishamawada
        • 174
        As mentioned before , it's a drum issue .
        For yellow it seems only a drum blade issue
        Cyan seems a drum issue. If you want u can try adjusting the background level or adjust the primary transfer voltage. it might give you more time before u change it
        Sent from my SM-G610F using Tapatalk
        • Synthohol
          Certified Konica Expert
          • 5847
          I beg to differ, the cyan dv is shot. Look at the diagonal voids on cyan blocks.
          Maybe a yellow drum issue too but the cyan dv unit definitely needs to be replaced.
          • tsbservice
            Field tech
            • 8020
            Print halftone test patterns from service mode at some diferent densities. That would expose faulty parts.
            • Lakatom
              • Jan 2021
              • 8
              Cyan got a new blade for a month, but the corona unit have a "foil", its cr*p, i don't know if that could be a problem.
              • Lakatom
                • Jan 2021
                • 8
                45-50%
                • Lakatom
                  • Jan 2021
                  • 8
                  https://imgur.com/1LXhCTN
                  https://imgur.com/tG424HO
                  https://imgur.com/74caMs6
                  https://imgur.com/HG7ulwk
                  https://imgur.com/RUZQEtT
                  I could not change the density
                  • tsbservice
                    Field tech
                    • 8020
                    Hit the clear button and then choose 128 with keys.
                    • Hishamawada
                      • 174
                      According to ur photos , since the cyan drum is on magenta now , then its a drum issue (the drum itself).
                      The yellow lines if not visible on the yellow prints as white lines then its a blade issue.
                      As i stated before u might play around the magenta drum . Better swap it on yellow and if issue is still visible on prints adjust the background and primary voltage.
                      • Synthohol
                        • 5847
                        Always print the cmyk gradation test pages. All 4.
                        So much more revealing of issues.
                        1 black pattern unfortunately does not help with a color problem.
                          • 23009
                          Try this set of originals:
                          • CP-1015
                            • Nov 2020
                            • 323
                            [ATTACH=CONFIG]48378[/ATTACH]
                            And table number?
