Konica 1250 toner piles on charging unit sides after 5000 copies
  • qaraman
    • Oct 2019
    • 17
    I have replaced the developing unit, a new charge unit, new cleaning unit assembly and a new drum, the problem still happens, I have also lowered the density to - 3, any ideas what should I do next? IMG-20210319-WA0000.jpgIMG-20210319-WA0001.jpgIMG-20210319-WA0002.jpgIMG-20210325-WA0025.jpg
  • GIUBOSS
    • 1392
    Re: Konica 1250 toner piles on charging unit sides after 5000 copies
    Originally posted by qaraman
    I have replaced the developing unit, a new charge unit, new cleaning unit assembly and a new drum, the problem still happens, I have also lowered the density to - 3, any ideas what should I do next? [ATTACH=CONFIG]48758[/ATTACH][ATTACH=CONFIG]48757[/ATTACH][ATTACH=CONFIG]48759[/ATTACH][ATTACH=CONFIG]48756[/ATTACH]
    Genuine toner?
    • qaraman
      • Oct 2019
      • 17
      Originally posted by GIUBOSS
      Genuine toner?
      Yes sir 100% Genuine.
        • 22999
        Have a look at the upper cleaning unit seal. It will wear to a tapered edge then fold over, and act like an additional charging device. =^..^=
        • qaraman
          • Oct 2019
          • 17
          Thanks for your reply, what you're saying makes sense, however the entire cleaner unit was replaced brand new for this issue.
          • Woxner
            • Jul 2011
            • 841
            perhaps the transfer belt is not transfering all the toner also replace transfer belt rollers. 951 does same thing.
            • qaraman
              • Oct 2019
              • 17
              Thanks for the reply, do you suggest I should replace transfer belt and rollers too?
              Sent from my ANE-TL00 using Tapatalk
              • allan
                RTFM!!
                • 5462
                If its done its yield or close to it. Not much to go wrong on the transfer belt assy.
                The toner dusting in that area would suggest a problem on the cleaning unit the cause of it is unknown but check that there is nothing deforming the cleaning blade.
                Whatever
                • qaraman
                  • Oct 2019
                  • 17
                  Thank you, will check on Monday. Regards,
                  • Albonline
                    • Sep 2008
                    • 1144
                    check the toner suction/anti misting system
                    • tulintron
                      • Jul 2014
                      • 668
                      • qaraman
                        • Oct 2019
                        • 17
                        Thanks for this, I have replaced the developer again and properly made the counters and developing replacing procedure, they have been running since 2 days, they did not call back so far, hopefully it is solved. Check also all seals and cleanin blades, all look fine.
                          • 22999
                          I seem to recall replacing a developing unit upper cover when the upper seal started curling back at the front and rear edges. It was around 8M prints. =^..^=
                          • qaraman
                            • Oct 2019
                            • 17
                            Yes, this would have been possible, however I changed the entire developing unit, this machine is now around 35M A4.
                            Thanks for the follow up, they still haven't called. :-)
