I-Series storage board & boot problem.
  • suomi
    • Oct 2008
    • 152
    Has anyone managed to format the storage board so that the device will boot with it.
  • tsbservice
    Field tech
    • 8020
    Re: I-Series storage board & boot problem.
    What's the problem? Stuck at 25%/50% booting?
    • suomi
      • Oct 2008
      • 152
      Yes.Always replaced with a new storage board. It would be cheaper if it could be formatted.
      • tsbservice
        Field tech
        • 8020
        Agree, Don't know solution yet other than replacement of Storage board. I hear some claimed that recovery FW helps, not in our cases.
        • Woxner
          • Jul 2011
          • 850
          There is a way to format these storage boards. You need a code.
          • avecosat
            • Jun 2012
            • 305
            There is a new version of the recovery firmware (RFKM BT2111242EN )
            • tmmdmmm
              • Apr 2021
              • 173
              I'll have to try this next time. Had two boards fail, the old version didn't work for me
              • suomi
                • Oct 2008
                • 152
                If you mean that service mode code ... Doesn't work.
                • suomi
                  • Oct 2008
                  • 152
                  Once tried. New version. Does not work.
                  Of course, the diagnostic tool shows the defective part. But it doesn't fix anything.
                  • Max
                    • Oct 2011
                    • 560
                    I have successfully formatted 2. One on 250i and 2nd on 550i. The smaller A4 colour doesn't want to know no matter what I did. I got a usb M2 adaptor and used disk management. Deleted all partitions that it let me, made them active and didn't assign any drive letters. Another way to use cmd to format it and make only one active partition but I yet to try it that way. Can't remember if I plugged a f/w on 1st boot up or not. Set to mem storage and input s.n and you loose all counters/ eu/us settings
                    • rrrohan
                      • Sep 2011
                      • 1977
                      Are they expensive? I assume they were the longer versions
                      Sent from my Pixel 4 XL using Tapatalk
                      • suomi
                        • Oct 2008
                        • 152
                        400 euros..Konica Minolta
                        • tsbservice
                          Field tech
                          • 8020
                          Yes and yes.
                          • rrrohan
                            • Sep 2011
                            • 1977
                            Pity they don't take PC shop nvme SSD.
                            • Albonline
                              • Sep 2008
                              • 1151
                              I've done over 20 of them using a m2 ssd adaptor and a utility called testdrive. remove all partitions and leave the drive raw and unformatted. looks just like a new drive to copier. (bad ssd's will preform sluggish and get hot while being wiped i toss these )
